Thread Number: 71902
Frigidaire Variable Speed Jet-Action Washer |
Post# 951273   8/2/2017 at 10:58 (2,451 days old) by Unimatic1140 (Minneapolis)   |   | |
I just posed the service manual from 1967 to Frigidaire washer model WXL. It's the first variable speed Frigidaire washer and describes how the solid-state variable speed clutch works, along with the roller-matic transmission.
One of my favorite things in this manual is this little tid-bit lol!... |
Post# 951294 , Reply# 1   8/2/2017 at 12:42 (2,451 days old) by bajaespuma (Connecticut)   |   | |
Post# 951297 , Reply# 2   8/2/2017 at 12:48 (2,451 days old) by realvanman (Southern California)   |   | |
Exactly how this variable speed works... If I had the machine, I would buy the download. :) |
Post# 951362 , Reply# 4   8/2/2017 at 22:40 (2,451 days old) by cfz2882 (Belle Fourche,SD)   |   | |
a disc type friction clutch was used,a magnetic coil providing pressure on the clutch discs-voltage to the coil modulated by a transistorized circuit monitoring clutch output RPM-a very high slippage rate for low speeds with this arrangement :) |
Post# 951696 , Reply# 5   8/5/2017 at 14:58 (2,448 days old) by MixGuy (St. Martinville, Louisiana)   |   | |
I cannot imagines this speed control arrangement being very durable. Especially with prolonged use at low speeds. There must have been something that needed repair frequently not to continue making such a speed control that was variable. |
Post# 952164 , Reply# 6   8/8/2017 at 12:06 (2,445 days old) by midcentnurse (Lake Charles, La)   |   | |
Post# 952231 , Reply# 8   8/8/2017 at 19:02 (2,445 days old) by Spinmon (st. charles mo )   |   | |
But,VACUUMING the sand out your washer blows. Sometimes the sand is hiding from the 'shakeout'. |
Post# 952298 , Reply# 9   8/9/2017 at 08:15 (2,444 days old) by panthera (Rocky Mountains)   |   | |
