Thread Number: 71918
/ Tag: Vintage Dishwashers
Single Rinse Kitchen Aids |
Post# 951416   8/3/2017 at 10:31 (2,449 days old) by jakeseacrest (Massachusetts)   |   | |
I currently have an Amana dishwasher from around 2013 and it's pretty good but the vintage bug is biting at me again. There is a Kitchen Aid dishwasher near me but I know it only has a single after rinse. Is it really necessary to have 2 post wash rinses? I'm pretty anal about clean dishes and worry about detergent residue left over. Am I being a worry wart?
Post# 951418 , Reply# 1   8/3/2017 at 10:37 (2,449 days old) by Frigilux (The Minnesota Prairie)   |   | |
I'm quite sure my 1984 KitchenAid had only one rinse after the wash. That took me by surprise as our 1974 Lady Kenmore seemed like it rinsed several times during the cycle; twice at the end. After the initial skepticism, I was very happy with the results from the KA.
I say go for it and enjoy the wonders of a vintage KitchenAid! |
Post# 951446 , Reply# 2   8/3/2017 at 14:39 (2,449 days old) by chetlaham (United States)   |   | |
Means little in terms of rinse-ability. You could theoretically have a machine with 8 post main washes rinses and still have more residue then a single rinse Whirlpool. I know because I've used 3 rinse GE and Dura-wash dishwashers that have left behind more detergent residue then single rinse Powercleans when the cup was over filled.
The low carry over water of the vertical module, post main wash purge which further reduces that carry over, and high water charge (2.2 gallons) offset the single rinse scheme. Most dishwashers that do two rinses do so because there is more carry over water (and often less water per fill ie, 1.8 gallons) thus making it necessary- and dishwashers with the most carry over like GE predominantly had 3 rinses. In fact GE in the 2000s had models with both a drain solenoid and aux pump. Everything was identical, but the aux pump model (which drained the sump after each solenoid drain) rid itself of one prewash and one rinse. Fill went from the typical 1.3 gallons on the BOLs to about 1.6 on the aux models to offset the water taken from the sump. 1.6 gallons and two fills is about what most other dishwashers did as they did not have several quarts carry over. |
Post# 951467 , Reply# 3   8/3/2017 at 18:18 (2,449 days old) by lesto (Atlanta)   |   | |
My old Kitchen Aid on;y has one final rinse and I've never had a problem with residue. |
Post# 951607 , Reply# 4   8/4/2017 at 16:27 (2,448 days old) by eronie (Flushing Michigan)   |   | |
My moms KDS23 does a sump purg to clean the filter after the main wash. Two plus clean filter and HOT water for the rinse. Total "Normal Cycle" water usage 9.5 gallons. Quiet too... |
Post# 951797 , Reply# 5   8/6/2017 at 05:15 (2,447 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 951800 , Reply# 6   8/6/2017 at 06:13 (2,446 days old) by joeypete (Concord, NH)   |   | |
