Thread Number: 72453
/ Tag: Modern Dryers
Speed Queen electric dryer - fried wire |
Post# 957465 , Reply# 1   9/14/2017 at 00:12 (2,414 days old) by rp2813 (Sannazay)   |   | |
Post# 957668 , Reply# 2   9/15/2017 at 15:01 (2,413 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
If it was on or near the heater and espically if it was the left rear roller that failed you vent system is partly cloged or certainly not ideal. A bad vent will cause the heater area to run hot and cause premature failures.
The component that the failed Wire was connected to weather the heater or a safety thermostat should have also been replaced to ensure a lasting repair. John L. |
Post# 957702 , Reply# 3   9/15/2017 at 19:27 (2,413 days old) by Lorainfurniture (Cleveland )   |   | |
There is a common failure wire ( common in a speed queen way i.e. Not common) near the timer or the heat selection switch. Replace the offending wire and whatever it plugs in to. |
Post# 957865 , Reply# 4   9/17/2017 at 12:02 (2,411 days old) by dzr (Nj)   |   | |
Thanks. The repair person reached it from removing the front bottom panel. I can't see that it would be either switch. |
Post# 957904 , Reply# 5   9/17/2017 at 19:01 (2,411 days old) by dzr (Nj)   |   | |
I also had the vent system professionally cleaned about 6 months ago. |
Post# 957915 , Reply# 6   9/17/2017 at 20:21 (2,411 days old) by Lorainfurniture (Cleveland )   |   | |
That was a heater wire. Odd that it would fail so soon. |
Post# 958125 , Reply# 7   9/19/2017 at 08:38 (2,409 days old) by mrb627 (Buford, GA)   |   | |
Post# 958167 , Reply# 8   9/19/2017 at 16:46 (2,409 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This is very common on electric dryers, that I've had a lot of use.
It was not caused by vibration, but most likely aggravated by a less than ideal vent situation, even though you say the vent system was cleaned recently is it really to the manufacturer specifications ? I would suggest running the dryer with the lower panel removed and a heavy load in it for a few minutes and see just how hot it's getting in the heater area if it's glowing bright red your vent system needs help. John L |
Post# 959755 , Reply# 9   9/28/2017 at 23:08 (2,400 days old) by dzr (Nj)   |   | |
Thank you! |
