Thread Number: 72527
POD 9/20/2017 |
Post# 958287 , Reply# 1   9/20/2017 at 10:32 (2,380 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 958300 , Reply# 2   9/20/2017 at 12:05 (2,380 days old) by mrb627 (Buford, GA)   |   | |
Post# 958307 , Reply# 3   9/20/2017 at 12:58 (2,380 days old) by DADoES (TX, U.S. of A.)   |   | |
A diverter mechanism changes the FilterFlo flow on a three-way flume. Soak (or Prewash) Agent or main wash Detergent if Soak or Prewash options aren't used - dumps directly into the filter pan. Water flow from the center flume, directly into filter pan (not through Dispensall tray). Granular Detergent - used for the main wash if Soak or Prewash is also used. Water flow from right flume, flushes Granular Detergent into the filter pan. Some water is also sent into the bleach dispenser to flush it. Softener - water flow through left flume to flush softener. An example, with colored water! GEExtraRinse - Dispensall 8/20/2006 |
Post# 958311 , Reply# 4   9/20/2017 at 13:23 (2,380 days old) by mrb627 (Buford, GA)   |   | |
Post# 958319 , Reply# 5   9/20/2017 at 14:16 (2,380 days old) by whitetub (Montreal, Canada)   |   | |
Once you put in your clothes, and the detergent, bleach, and fabric softener, and start the washer, could you still open the lid and add some clothes? Or was that out of the question because all your liquids would start dripping everywhere from the dispensall system ? |
Post# 958342 , Reply# 6   9/20/2017 at 18:01 (2,380 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 958347 , Reply# 7   9/20/2017 at 18:25 (2,380 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
