Thread Number: 72578
1996 Maytag Dependable Care squeal during agitation only |
Post# 958920 , Reply# 1   9/24/2017 at 16:44 (2,404 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 958939 , Reply# 3   9/24/2017 at 20:33 (2,403 days old) by cfz2882 (Belle Fourche,SD)   |   | |
could take the pump belt off and let it run through the agitation cycle-see if the squeal is still there... |
Post# 958942 , Reply# 4   9/24/2017 at 21:04 (2,403 days old) by orbital (Toronto)   |   | |
Thanks - I will try that tomorrow. I am hoping it is something relatively simple like the pump. |
Post# 958947 , Reply# 5   9/24/2017 at 21:56 (2,403 days old) by askolover (South of Nash Vegas, TN)   |   | |
Mother's did that about 20 years ago. I talked to the local Maytag guy about it. He said more than likely something like a straight pin had gotten to the pump and that it would eventually break off and cease to be heard. He must have been correct because in a couple of days it stopped and hasn't done it since. I don't know if this is your problem though, just thought I'd throw it out there. |
Post# 959149 , Reply# 7   9/26/2017 at 00:16 (2,402 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 959481 , Reply# 9   9/27/2017 at 17:34 (2,401 days old) by orbital (Toronto)   |   | |
Sound came back and I isolated it to the pump. Thanks for pointing me in that direction. |
Post# 959485 , Reply# 10   9/27/2017 at 17:45 (2,401 days old) by pumpkina (California)   |   | |
Great! Was there a straight pin or other foreign body in the pump? Does anyone know why the sound is limited to the last couple minutes of agitation? |
Post# 959749 , Reply# 12   9/28/2017 at 21:55 (2,399 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 960118 , Reply# 14   10/1/2017 at 21:51 (2,396 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
They never really need oil but you can remove the little screw between the top and bottom bearing and put a few drops of light machine oil in and then replace the screw.
If the bearings have gotten so dry that they are actually the cause of the noise they are very damaged and the pump should be replaced if you want it to last long.
Most times these pumps start squealing there is either something stuck in the pump or the rubber impeller has swelled a little and is rubbing on the inside of the housing. So unless you can knock or fish a foreign object out of the pump they are better replaced.
