Thread Number: 72605
Powerclean crosses the rainbow bridge |
Post# 959210 , Reply# 1   9/26/2017 at 07:46 (2,397 days old) by potatochips ( )   |   | |
What replaced it will be apart of the next Legends series. |
Post# 959227 , Reply# 2   9/26/2017 at 09:32 (2,396 days old) by pumpkina (California)   |   | |
You're talking about a dishwasher, right? What is the cause of the arcing out? |
Post# 959307 , Reply# 4   9/26/2017 at 16:57 (2,396 days old) by kb0nes (Burnsville, MN)   |   | |
They were likely near the current limit for those particular terminals in the harness. Get a little moisture there and some thermal cycling and the connector starts to build a little resistance. Now it gets hot and increases the thermal cycling and degradation. It is a run away failure.
Of course this is of no help now that the connector is destroyed, but had this product been brushed on those connectors years ago, the connector would never fail. I've been using this stuff religiously on electrical connections since I learned of it in 30 years ago. Amazing the condition it keeps connections in. |
Post# 959317 , Reply# 5   9/26/2017 at 17:48 (2,396 days old) by Yogitunes (New Jersey)   |   | |
Post# 959337 , Reply# 6   9/26/2017 at 20:27 (2,396 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This can be fixed if you can find a good timer for the dishwasher, replace the timer and take three leads with the correct little terminals on them and just place it into the harness, you can carefully Cut away the damaged part of the black connector block.
We do this type of repair all the time and it will last a long time, if you use the material Phil suggested it'll probably last far longer than it did the first time. |
Post# 959374 , Reply# 8   9/27/2017 at 06:05 (2,396 days old) by Tomturbomatic (Beltsville, MD)   |   | |
I am certainly glad to hear that Powerclean was not a dog. |
Post# 959393 , Reply# 9   9/27/2017 at 08:40 (2,395 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
here is a link where you might find the part your looking for to fix your inglis powerclean dishwasher depending on the model?
www.partselect.ca/Inglis-... |
Post# 959407 , Reply# 10   9/27/2017 at 10:33 (2,395 days old) by potatochips ( )   |   | |
The timers part number is 20083477. I cant find anything on eBay or any appliance parts website. Ill hold off for about four months and if by then theres no timer, I think I may just part the machine out. |
Post# 959453 , Reply# 11   9/27/2017 at 15:09 (2,395 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 959454 , Reply# 12   9/27/2017 at 15:18 (2,395 days old) by potatochips ( )   |   | |
Greg, you saved the day. |
Post# 959499 , Reply# 13   9/27/2017 at 19:52 (2,395 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Potato, that's what killed my KM PowerClean! |
