Thread Number: 72611
Kenmore Portable Washer Shakes Excessively |
Post# 959284 , Reply# 1   9/26/2017 at 14:50 (2,401 days old) by Yogitunes (New Jersey)   |   | |
Post# 959285 , Reply# 2   9/26/2017 at 14:53 (2,401 days old) by pumpkina (California)   |   | |
Thanks. That's what I thought. The 225 lb figure comes from here: www.kenmore.com/products/... |
Post# 959287 , Reply# 3   9/26/2017 at 15:02 (2,401 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 959290 , Reply# 4   9/26/2017 at 15:14 (2,401 days old) by Yogitunes (New Jersey)   |   | |
I guess with my bionic arm, I forget how much these weight as I have two of them, and lift them myself in and out of the Jeep taking them to events for show and tell...
Walmart is showing these machines from 1.0 cuft capacity at 43lbs...and the 1.7 at upwards of 77lbs.... also, if you don't add a link, an icon wont show up to check for one.... |
Post# 959292 , Reply# 5   9/26/2017 at 15:24 (2,401 days old) by nmassman44 (Brooksville Florida)   |   | |
Thats not even the same model in the above pic. The one in the link is a completely different animal altogether. The one in the above pic is agitator based and the link one is impeller based. The washer in the Whirlpool version is LCE4332P and weighs a whopping 85 lbs and with water filled to High and clothes...max weight is 260 lbs total.
The above washer uses a rod and spring suspension system and it could be that one of the rods is out of the holder in one of the 4 corners. There are 4 rods in this washer. This washer is also called a "World Washer" since more than likely it had its birthplace in Brazil. Its also belt driven. |
Post# 959293 , Reply# 6   9/26/2017 at 15:31 (2,401 days old) by nmassman44 (Brooksville Florida)   |   | |
Model
Brand: Whirlpool SKU: LCE4332PQ UPC: 050946962948 Stock Id: 21494 Product Number: WPLCE4332PQ Appearance Color: White Type: Top Load Capacity: 2.1 cu. ft. Control Type: Touchpad Technical Details Energy Star: Yes Portable: No ADA Compliant: No Reversible Door: No Location of Controls: Rear Type of Controls: Touchpad Bleach Dispenser: Yes Stainless Steel Drum: Yes Fabric Softener Dispenser: Yes Self Cleaning Lint Filter: No Soak Setting: No Number of Cycles: 4 CEE Rating: Not Available Weight: 85.00 lbs Dimensions Width: 22 5/16" Height: 38 1/4" Depth: 24.625" Details Volts: 120 Volts Amps: 15A Stackable: No Features Temperature Settings: 3 Usage: Residential Steam Cycle: No Water Heater: No Wash Cycles: 4 Leveling Legs: Yes Connect With Us This info I found online. |
Post# 959316 , Reply# 7   9/26/2017 at 17:45 (2,401 days old) by Yogitunes (New Jersey)   |   | |
Post# 959322 , Reply# 8   9/26/2017 at 18:04 (2,401 days old) by pumpkina (California)   |   | |
I wasn't clear: I haven't yet seen it in person. This evening, I'll look at it and post the model and serial number. Thanks for your help thus far! |
Post# 959324 , Reply# 9   9/26/2017 at 18:16 (2,401 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 959325 , Reply# 10   9/26/2017 at 18:18 (2,401 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 959349 , Reply# 11   9/26/2017 at 22:56 (2,400 days old) by pumpkina (California)   |   | |
Kenmore Washer 44722 Model Number 110.44722400 Serial Number CRR4306120 Despite being level and having balanced loads, washer vibrates a lot during spin cycle. What should I look for to fix this? Thanks |
Post# 959355 , Reply# 12   9/26/2017 at 23:43 (2,400 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 959363 , Reply# 13   9/27/2017 at 01:18 (2,400 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 959365 , Reply# 14   9/27/2017 at 01:31 (2,400 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
I know this washer from soul... Suspension arms worn or missing the coils. Or the plastic sleeve is broken. Simple as that, super easy fix. Also check if the motor counterweight is on it's place.... if it falls, the motor weigh causes an unbalance. |
Post# 959369 , Reply# 17   9/27/2017 at 01:59 (2,400 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Forgot to mention... i don't remember how are the top covers in the american version... Maybe it may have two screws on the front corner or just a clamp that you lift the cover and push it from the back to the front. |
Post# 959370 , Reply# 18   9/27/2017 at 02:00 (2,400 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
BTW, thsi washer isn't the lightest ever, but it's never that heavy... unless it's full of water up to the top. |
Post# 959401 , Reply# 19   9/27/2017 at 09:36 (2,400 days old) by pumpkina (California)   |   | |
Thanks. How do I check the motor for an intact counter-weight? |
Post# 959418 , Reply# 21   9/27/2017 at 11:56 (2,400 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
That was my first guess... They can break by fatigue or overload or simply because they got too old and brittle. Easy fix. even easier... |
Post# 959426 , Reply# 22   9/27/2017 at 12:23 (2,400 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 959431 , Reply# 23   9/27/2017 at 12:53 (2,400 days old) by pumpkina (California)   |   | |
Thanks thomasortega referenced the motor counterweight: "Also check if the motor counterweight is on it's place.... if it falls, the motor weigh causes an unbalance." How do I check the motor and the drum counterweight? |
Post# 959437 , Reply# 24   9/27/2017 at 13:30 (2,400 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
The counterweight is a metal block attached to the tub, opposite to the motor. But as mentioned above, the straps are missing (probably broken, so you'll find a piece of them right down the suspension arm and another piece hanging on the top of the tub) Missing straps is the very first cause of OOB. |
Post# 959442 , Reply# 25   9/27/2017 at 14:00 (2,400 days old) by Yogitunes (New Jersey)   |   | |
