Thread Number: 72650
POD 09/30/2017 |
Post# 959910 , Reply# 1   9/30/2017 at 11:52 (2,397 days old) by appnut (TX)   |   | |
Post# 959925 , Reply# 2   9/30/2017 at 13:24 (2,397 days old) by retro-man (- boston,ma)   |   | |
What if you didn't want bleach in a load, how did you do that. Does the lever go down all the way so no bleach is added? Jon |
Post# 959926 , Reply# 3   9/30/2017 at 13:34 (2,397 days old) by HiLoVane (Columbus OH)   |   | |
I, too liked the 1957-60 GE FF washers. Don't know why they couldn't retain the 68SPM agitation when they switched to a perforated tub. I personally never cared for spiral-vane agitators. But, that's just me. |
Post# 959928 , Reply# 4   9/30/2017 at 14:00 (2,397 days old) by DADoES (TX, U.S. of A.)   |   | |
Retro-Man: What if you didn't want bleach in a load, how did you do that. Does the lever go down all the way so no bleach is added?I believe the procedure is pump the lever multiple times until the sight-window indicates the desired dose is loaded-to-go from the filled reservoir (maybe 1/4 cup per pump?). Don't pump the lever if bleach is not desired. |
