Thread Number: 72662
Maytag a806 washer will not spin dry |
Post# 960127 , Reply# 1   10/1/2017 at 23:41 (2,369 days old) by rp2813 (Sannazay)   |   | |
Post# 960130 , Reply# 2   10/1/2017 at 23:53 (2,369 days old) by brucelucenta ()   |   | |
Timer of course. |
Post# 960144 , Reply# 3   10/2/2017 at 04:43 (2,369 days old) by tagok (Oklahoma)   |   | |
Many thanks to you all for your excellent help! I should be able to find a timer on ebay, but if there is better place to loate one please let me know. |
Post# 960151 , Reply# 4   10/2/2017 at 05:23 (2,369 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 960165 , Reply# 5   10/2/2017 at 06:57 (2,369 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
if you're handy at all you might try opening your timer up to have a look. The symptom you're describing can be caused by fouled contacts in which case you might have a go at cleaning them up with some emery cloth or something similar. Fouled contacts are easy to spot and they should be accessible on both Kingston and Mallory timers. It's worth a try anyways.
Post# 960216 , Reply# 6   10/2/2017 at 11:17 (2,369 days old) by pumpkina (California)   |   | |
Is there any spray or chemical you can put on fouled contacts to prevent this from happening again? |
Post# 960222 , Reply# 7   10/2/2017 at 12:17 (2,369 days old) by Yogitunes (New Jersey)   |   | |
Post# 960232 , Reply# 8   10/2/2017 at 13:24 (2,368 days old) by pumpkina (California)   |   | |
I mean once the timer is open and the contacts are exposed, is there something to put on them to prevent fouling in the future? |
Post# 960235 , Reply# 9   10/2/2017 at 13:53 (2,368 days old) by Yogitunes (New Jersey)   |   | |
Post# 960282 , Reply# 10   10/2/2017 at 19:27 (2,368 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Post# 960287 , Reply# 11   10/2/2017 at 19:52 (2,368 days old) by Yogitunes (New Jersey)   |   | |
Post# 960293 , Reply# 12   10/2/2017 at 20:27 (2,368 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
but not the final spin, yes it has timer problems, it is a bad cam however and NOT bad contacts and unless you want to build the cam back up with epoxy and precisely regrind it to orignal dimensions it is NOT repairable, find another new, rebuilt or used timer.
Timer contacts that handle 120 volts and 700 watts DO NOT get dirty and there is nothing that should be sprayed on them, you can spray some silicone lubricant on the timer cam if you like to make the timer turn and advance more smoothly if you like.
Post# 960588 , Reply# 14   10/4/2017 at 14:28 (2,366 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 960738 , Reply# 15   10/5/2017 at 09:59 (2,366 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
Post# 961206 , Reply# 17   10/7/2017 at 18:35 (2,363 days old) by speedqueen (Metro-Detroit)   |   | |
Try disconnecting the belts and see if it turns then, also try moving the transmission pulley and check for excess resistance. Another thing, make sure that the motor carriage is clean and rust free as well as glides easily and smoothly, without the clutching action provided by the slip type belts and the motor carriage being free, it could easily trip the thermal overload. Does it have OEM Maytag belts, or aftermarket? That could make all the difference.
Check the pump too, it could be frozen or jammed. |
Post# 961287 , Reply# 18   10/8/2017 at 05:25 (2,363 days old) by TAGok (Oklahoma)   |   | |
d-jones, I am going to keep the old timer for now. I might need it later on. I found out the old motor part number is 2-1666, and the new motor 12002353 is correct according to maytagreplacementparts.com catalog. |
Post# 961299 , Reply# 20   10/8/2017 at 07:24 (2,363 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
