Thread Number: 72670
/ Tag: Vintage Dryers
Are Old School Hotpoint Dryers Good to Have? Intermittent Squealing |
Post# 960239 , Reply# 1   10/2/2017 at 14:10 (2,391 days old) by pumpkina (California)   |   | |
It's erroneously listed under dishwahsers, but I swear I selected vintage dryers. |
Post# 960240 , Reply# 2   10/2/2017 at 14:34 (2,391 days old) by Yogitunes (New Jersey)   |   | |
Post# 960258 , Reply# 3   10/2/2017 at 16:53 (2,390 days old) by pumpkina (California)   |   | |
They want to know if it's a reliable used brand and if it's worth getting it fixed. |
Post# 960261 , Reply# 4   10/2/2017 at 17:18 (2,390 days old) by Yogitunes (New Jersey)   |   | |
Post# 960264 , Reply# 5   10/2/2017 at 17:33 (2,390 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 960316 , Reply# 6   10/2/2017 at 22:38 (2,390 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Is most often a worn out rear drum bearing, at the least you need a new Teflon bearing insert and a shaft if to is worn or scored.
The front slides are also a possibility, if they are completely worn down to the metal you may need a new drum.
The rear bearing should not be lubricated at all, the felt on the front slides can be lubricated with silicone oil.
Post# 960511 , Reply# 7   10/3/2017 at 23:31 (2,389 days old) by norgeway (mocksville n c )   |   | |
Dryer and washer to match, great machines. |
Post# 960613 , Reply# 8   10/4/2017 at 16:02 (2,388 days old) by CircleW (NE Cincinnati OH area)   |   | |
Basically the same as all standard GE dryers made after 1957. The house I rented has a slightly newer version in the basement. |
Post# 960638 , Reply# 9   10/4/2017 at 19:13 (2,388 days old) by Paulwash (Niagara Falls New York)   |   | |
Ehhh... my best friends mother gave me one of those. It was a 1986 model. She had the matching washer. The dyer squeaked, struggled, and stalled. It also overheated. I didn't like it and sent it back to her. The tub would get scorching hot !!! Then I had a GE dryer overheat from the early 80's I think they are dangerous dryers. I like Kenmore,Whirlpool, Kitchen Aid, Estate, and Roper dryers the best.
Post# 960641 , Reply# 10   10/4/2017 at 19:35 (2,388 days old) by Yogitunes (New Jersey)   |   | |
Post# 960642 , Reply# 11   10/4/2017 at 19:39 (2,388 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Paul you are right on the money, these were ok dryers at some points during this time period, but after WP got their new design going in 1966 after this time these GE-HP dryers were too small, too hot and just crude, I will still rate them above the MT HOH dryers.
But today they are basically museum pieces are a testament to how cheaply GE could build a 1/2 way decent clothes dryer.
But this is a group of appliance collectors and as such we should know better when selecting vintage appliances that we want for are own use.
Post# 960649 , Reply# 12   10/4/2017 at 20:23 (2,388 days old) by Yogitunes (New Jersey)   |   | |
Post# 960696 , Reply# 13   10/5/2017 at 05:04 (2,388 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 960700 , Reply# 14   10/5/2017 at 05:47 (2,388 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 960728 , Reply# 15   10/5/2017 at 09:04 (2,388 days old) by Paulwash (Niagara Falls New York)   |   | |
Post# 960750 , Reply# 16   10/5/2017 at 12:07 (2,388 days old) by rp2813 (Sannazay)   |   | |
I guess it depends on the circumstances. Our HOH DG806 got a full load of towels perfectly dry in 45 minutes or less, even though they had been spun out at not-so-impressive A206 washer RPM.
I agree that the WP design is probably the best ever, and we had a Kenmore pair for a few years, but I've never understood the HOH bashing. That 806 was the best dryer I've ever owned. Quiet, fast, efficient, and no dryer could be any easier to use. |
Post# 960763 , Reply# 17   10/5/2017 at 12:54 (2,388 days old) by LordKenmore (The Laundry Room)   |   | |
I have to say I've used GE dryers twice, and didn't like either one. One was older--say ca. 1970--and the other was a Hotpoint similar to the one pictured above. It seemed like both took forever to dry, and didn't seem to get as hot as a Kenmore. There may, of course, have been some issue. I never made much attempt to figure that out--both dryers were "there" because they were provided as part of a rental. (I did make some effort to clean lint out of the Hotpoint.) Oh, yes...the Hotpoint also had a squeaky noise. I can't remember for sure, but that noise might have been intermittent. I can't remember for sure--it's been a while, and frankly that Hotpoint is not something I really have an interest in remembering.
Post# 960767 , Reply# 18   10/5/2017 at 13:08 (2,388 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 961434 , Reply# 20   10/9/2017 at 03:06 (2,384 days old) by askolover (South of Nash Vegas, TN)   |   | |
Grandmother had a 60's GE dryer and to my knowledge it NEVER required any service the entire time she owned it which was over 40 years! My 98 GE has only had the front bulkhead sliders replaced and dries really fast. I've never cared for WP dryers because of the way the heat stream travels inside the drum although they certainly do last a long time. My first dryer was an old $50 WP dryer that worked just fine except when I dried comforters in it and had to take the load out, turn it around and stick it back in to let it dry the other side. My GE will dry it completely with no intervention from me. |
