Thread Number: 72767
/ Tag: Classified Ad Finds
BEAUTIFUL RARE PILOT 6B500 TUBE STEREO CONSOLE - $650 (Northville) |
Post# 961403   10/8/2017 at 22:39 (2,384 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
..this would normally go into Ultramatic's "Vintage Electronics.." but I wanted to make sure some people I know see this one. $$$
CLICK HERE TO GO TO ovrphil's LINK on Detroit Craigslist |
Post# 961457 , Reply# 1   10/9/2017 at 07:01 (2,384 days old) by norgeway (mocksville n c )   |   | |
Any good, I have never seen but one or two of them around here. |
Post# 961479 , Reply# 2   10/9/2017 at 09:18 (2,383 days old) by panthera (Rocky Mountains)   |   | |
Used good components - that Garrard turntable is very much OK and the output transformers in the power-amp are over-dimensioned for the relatively low power their putting out. I didn't see the speakers, but if they're typical for the era in being well over 95% efficient, then, yes, this console would have been capable of the full dynamic range of Tchaikovsky's 1825 Overture. Pretty cabinet and orderly assembly in any case. |
Post# 961499 , Reply# 3   10/9/2017 at 12:06 (2,383 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
were among the best ever made, short only of custom builds using Marantz & McIntosh components or TOL Fishers, equivalent to Fisher's mid-upper models. This one sold for around $900 ca 1961-2. We've had 2 Pilot consoles over the last 20 yrs, both using the same super nice SA-232 component 4 x EL-84 output tube stereo amplifier and FA-690 tuner-preamp shown here. A few Pilot consoles had their TOL SA260 EL-34 amp, that amp now selling for $1500+ when you can find one.
The fine and desirable SA232 amp alone can bring $800-900+ nowadays. The unit shown behind the amp is the stand-alone multiplex unit. The tuner preamp section is quite excellent, not dissimilar in design to the SP215 , one of which we've had (and should have kept), and SP216 preamps, both bringing $1500-2000 these days. Dick Sequerra and Sid Smith (of Marantz 10c tuner fame) both worked as engineers at Pilot, who'd been making radios since the 1920s. This particular Garrard is decent, their mid-line/econo model. The component speakers were not proprietary but OEM Jensen and a few others. Anyone nearby should grab this ...asap!! Thanks for posting Phil!
Post# 961501 , Reply# 4   10/9/2017 at 12:23 (2,383 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
is a slow warm up 5AR4.
On closer examination this amp section, while very similar to the SA-232, seems to have been a console-only model, positioned just below in their line, the opt X-frmers are a tad smaller, tube layout slightly different, though tube complement and the big pwr x-frmer are the same. Transformer size, all things being equal, are a pretty good reflection of sound quality, iirc Pilot often used Magnetic Windings units, but memory isn't what it used to be... |
Post# 961503 , Reply# 5   10/9/2017 at 12:29 (2,383 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
as he says it's a 500 amp, which would indeed be a console-specific amp, and the console sold for ~ $600, then goes on to mention the SA-232. Most likely a very fine sounding console nonetheless. One with the 232 would have sold for $900-1100, according to my contemporaneous references. Please someone snag this thing!
Post# 961624 , Reply# 6   10/9/2017 at 22:48 (2,383 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 962135 , Reply# 8   10/12/2017 at 12:13 (2,380 days old) by speedqueen (Metro-Detroit)   |   | |
Listing has been deleted and re-posted now at $550, down from $600.
CLICK HERE TO GO TO speedqueen's LINK on Detroit Craigslist |
Post# 962142 , Reply# 9   10/12/2017 at 12:46 (2,380 days old) by speedqueen (Metro-Detroit)   |   | |
Post# 962164 , Reply# 10   10/12/2017 at 15:44 (2,380 days old) by kb0nes (Burnsville, MN)   |   | |
Post# 962322 , Reply# 11   10/13/2017 at 16:52 (2,379 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
Post# 962429 , Reply# 12   10/14/2017 at 08:31 (2,378 days old) by panthera (Rocky Mountains)   |   | |
When I referred to the 95+ efficiency. Roger A. already posted the entire characteristic above - at one meter, the amount of sound pressure per watt input. So, yeah, sorry about that, in the end, this 'little' power amp coupled with high efficiency speakers sounds more than loud enough. This post was last edited 10/14/2017 at 09:04 |
Post# 962491 , Reply# 13   10/14/2017 at 14:22 (2,378 days old) by kb0nes (Burnsville, MN)   |   | |
After I posted it dawned on me you meant sensitivity, lots of people consider that the same thing. If only there was a 95% efficient speaker then we could all get by fine with a couple watt amplifier. An acoustic watt is about the right amount of power into my room, but we need a couple hundred watts of amp power to get that.
The down side of sensitive/efficient speakers is they have lots of resonances that go undamped. But that is the sound of the 50's I suppose |
Post# 962512 , Reply# 14   10/14/2017 at 15:20 (2,378 days old) by rp2813 (Sannazay)   |   | |
The only Pilot Radio item I've ever had any experience with was a tiny early portable TV set (similar to the one pictured below). It had a 3" screen, but it didn't work. It belonged to a friend I knew around 1970 when such things were considered junk by repair shops.
I sort of remember PR being a respectable brand, but had no idea they produced fine quality audio consoles like the one pictured above. No wonder we had an Airline console instead.
Post# 962515 , Reply# 15   10/14/2017 at 15:22 (2,378 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 962904 , Reply# 16   10/16/2017 at 16:39 (2,376 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
I believe that 1948 Pilot set was the first TV to sell for less than $100. Pilot built some very nice stereo receivers around 1960. |
Post# 963002 , Reply# 17   10/17/2017 at 10:45 (2,375 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
