Thread Number: 72783
/ Tag: Twin-Tub Washers
Hotpoint Spin can bellows/seal |
Post# 962055 , Reply# 2   10/12/2017 at 01:42 (2,387 days old) by Slowspin66 (lincoln uk)   |   | |
Dear Rebeca only a thought as I had a very similar problem with a hoovermatic a few months ago . Have you stripped the spinner down and examined the lower part of the spin can that provides the counterface seal the the spin resilient mount . Under the spin can on my machine is a silver coloured cloaking that goes over the drive shaft and seats under the spinner can . This provides the counterface to the rubber mount . You can see the difference in the metal colours easily . Under the collar is a rubber washer that provides a seal between the two surfaces . . Because my machines are generally quiet old ladies the rubber o ring had pertished and water was leaking between the two components . It’ looked like it was the resilient mount when in fact it was this pesky o ring seal really easy to fix as cleaned with a wire brush all items and reassembled with silicone . Worked fine . Worth a strip down and looking at . Not sure which model yours is ???
