Thread Number: 73023
I acquired a few things & may need help |
Post# 964554   10/27/2017 at 15:28 (2,371 days old) by Doug (West Virgina)   |   | |
I got these for free dryer works but the lady said the washer wouldn't drain the water out and she had to dip it out with a bucket however I had no problem with it draining but when I put it on spin sometimes it would spin and sometimes it wouldn't and sometimes it would start to take off and then kind of drag an stop, other times it takes off and spends fine, But i don't think it's spinning in full speed either, it's not stuck on gentle because it spins slower on gentle? It agitates fine! I don't know very much about these kenmores so any help/suggestions would be great
Post# 964556 , Reply# 1   10/27/2017 at 15:35 (2,371 days old) by Doug (West Virgina)   |   | |
The agitator and stripped in the washer but it is quiet for a two speed dryer is also supposed to work but haven't tried it yet
Post# 964558 , Reply# 2   10/27/2017 at 15:47 (2,370 days old) by akronman (Akron/Cleveland Ohio)   |   | |
First thing to try is tightening the belt, I've seen other WP/KM act like that when the belt is too loose.
Unplug machine, take off the small rear lower panel. Right near the left top of the rear opening, there is a bolt on top of the baseplate, holding the motor in place. Loosen the bolt, use a huge screwdriver as a lever to push the motor towards the left side of the washer(as viewed from the rear) Tighten that bolt, plug her in and check the spin and pumping! |
Post# 965075 , Reply# 3   10/31/2017 at 00:55 (2,367 days old) by Doug (West Virgina)   |   | |
Post# 965194 , Reply# 4   10/31/2017 at 18:45 (2,366 days old) by potatochips ( )   |   | |
Nice finds, Doug! Really like that Hotpoint dryer too, |
Post# 965198 , Reply# 5   10/31/2017 at 19:22 (2,366 days old) by Doug (West Virgina)   |   | |
Post# 965199 , Reply# 6   10/31/2017 at 19:25 (2,366 days old) by Doug (West Virgina)   |   | |
Post# 965224 , Reply# 7   10/31/2017 at 22:06 (2,366 days old) by Doug (West Virgina)   |   | |
Post# 965311 , Reply# 8   11/1/2017 at 07:16 (2,366 days old) by pulltostart (Mobile, AL)   |   | |
Post# 965391 , Reply# 9   11/1/2017 at 14:07 (2,366 days old) by Doug (West Virgina)   |   | |
