Thread Number: 73161
2010 VMW cabrio in use... |
Post# 966564 , Reply# 2   11/7/2017 at 10:09 (2,360 days old) by Yogitunes (New Jersey)   |   | |
the direct drive unit is a better machine/choice overall.....plenty of water used for washing, and a sprinkler, which could be 'on' more than it is...
the belt drive worked well, but wasn't the best, a sprinkler/waterfall would have helped greatly.....you had a choice, add some more water for better performance, or pour a gallon of water over the load before starting, tricking the machine in to thinking there was a larger load...also found this version to play around 'pausing' a lot for each function...they could have easily shaved off 10 minutes of the cycle from all that playing around.... but as newer models got built, many concerns were addressed, they were getting better and better.... |
