Thread Number: 73346
Lady Kenmore portable washer has a bad timer |
Post# 968773   11/18/2017 at 16:45 (2,349 days old) by Maytag85 (Sean A806)   |   | |
Post# 968792 , Reply# 1   11/18/2017 at 17:44 (2,349 days old) by Yogitunes (New Jersey)   |   | |
Post# 968813 , Reply# 2   11/18/2017 at 19:41 (2,349 days old) by speedqueen (Metro-Detroit)   |   | |
Post# 968816 , Reply# 3   11/18/2017 at 20:11 (2,349 days old) by Maytag85 (Sean A806)   |   | |
Post# 968818 , Reply# 4   11/18/2017 at 20:21 (2,349 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The first thing to do when water will not shut off is unplug the machine, if it keeps filling you have a bad inlet valve.
If it only fills when plugged in it could be a bad timer or shorted wiring.
But it would really help if when you [ or anyone else for that matter ] would post a model # of the machine in question, as a rule I do not waste my time guessing when the person seeking advice will not even supply basic information.
Post# 968820 , Reply# 5   11/18/2017 at 20:29 (2,349 days old) by speedqueen (Metro-Detroit)   |   | |
Post# 968825 , Reply# 6   11/18/2017 at 20:38 (2,349 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Will chime in with others and say a bad fill solenoid/fill valve is a likely culprit.
What probably is happening is the fill valve/solenoid is stuck in "energized" and thus failing to respond when washer (via pressure switch or timer) tells it to stop filling. www.partselect.com/Repair... |
Post# 968900 , Reply# 7   11/19/2017 at 09:15 (2,348 days old) by nmassman44 (Brooksville Florida)   |   | |
It could also be that someone might have taken the inlet screens out of the valve and now something got into the valve like sand or a chunk of calcium from the plumbing and it won’t let the valve piston reseat itself to close off the water flow. I am willing to bet this person might also have grit in their water.
Post# 968968 , Reply# 8   11/19/2017 at 18:46 (2,348 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Even if it is grit or whatever causing the solenoid to jam open, it still wants replacing.
Anything that *might* be done to dislodge a "jam" will require taking the thing out anyway. Once you've gone down that path just as easy to replace with new and be done. IIRC taking apart solenoids to "repair" is rarely worth the bother. |
Post# 968990 , Reply# 9   11/19/2017 at 20:40 (2,348 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 969017 , Reply# 10   11/20/2017 at 00:54 (2,347 days old) by Maytag85 (Sean A806)   |   | |
Post# 969040 , Reply# 11   11/20/2017 at 04:29 (2,347 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 969043 , Reply# 12   11/20/2017 at 05:15 (2,347 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
If the solenoids are buzzing/humming when you pull out the timer, but no water is connected; well they would wouldn't they? The thing or things are calling for water but none is coming.
Should these sounds come from any where timer is pointed that requires machine to fill with water, and you've pulled out said device (started machine/energized solenoid), but you've disconnected water, again the valves are dead or going. One small mercy for you is that the washer in question is portable and not (assuming) permanently connected to water. People have flooded out their laundry areas/homes thanks to a stuck solenoid in washing machine. Simply put regardless of the timer being at an "off" position or not, long as there is electric power to the machine solenoid (if faulty and stuck in "open") will continue to allow water into tub. Just like a sink or tub when taps are left running, a top loader (or even some dishwashers) will continue to fill under such circumstances with water having to go *somewhere*. Many modern dishwashers and front loading washing machines have *water control systems* designed to (among other things) shut/block off water in hose from the tap when leaking/excess water situation is detected. |
