Thread Number: 73405
early forced air residential furnaces... |
Post# 969448 , Reply# 3   11/22/2017 at 19:42 (2,340 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
As a kid, we originally had a coal/wood Wood and Bishop furnace, made right in Bangor. Eventually an oil burner was added where the bottom door was before I was born and a wooden box with a big fan created the forced air. In the mid 60's, heat exchanger cracked and was replaced with a Sears Homart that was MUCH warmer. But it was mid to late 50's before gravity hot air furnaces (octopuses)were helped with an add on unit around here as fuel oil was cheap then and it was worth converting. By the late 50's, nobody messed with coal or wood it seemed.
Post# 969456 , Reply# 4   11/22/2017 at 20:57 (2,340 days old) by cfz2882 (Belle Fourche,SD)   |   | |
found 1935 was first year for lennox forced air residential.One of the earlier direct drive blowers I had found,~1961,had a Delco "inside out"motor in the center of the wheel. |
Post# 969461 , Reply# 5   11/22/2017 at 21:43 (2,340 days old) by GusHerb (Chicago/NWI)   |   | |
My grandma's 1960 Carrier had a direct drive blower. |
