Thread Number: 73420
/ Tag: Modern Dishwashers
The Miele Buzz |
Post# 969572 , Reply# 1   11/23/2017 at 15:34 (2,343 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
That is the sound of the motor stalling. Either (as common on this series) the motor/pump bearings are starting to seize up, or maybe its just the motor capacitor on its way out. |
Post# 969574 , Reply# 2   11/23/2017 at 15:41 (2,343 days old) by Spacedogb (Lafayette, LA)   |   | |
Is the capacitor a replaceable part or does the whole motor unit need to be replaced? |
Post# 969576 , Reply# 3   11/23/2017 at 15:44 (2,343 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Not sure, but I think its pretty easily replaceable IIRC. I think its just behind one of the side panels. Might be mixing things up though, so no warranty on what I say. |
Post# 969583 , Reply# 4   11/23/2017 at 16:59 (2,343 days old) by richnz (New Zealand)   |   | |
Also, why does the display not show anything? |
Post# 969584 , Reply# 5   11/23/2017 at 17:01 (2,343 days old) by mielerod69 (Australia)   |   | |
Post# 969586 , Reply# 6   11/23/2017 at 17:54 (2,343 days old) by Spacedogb (Lafayette, LA)   |   | |
Yes the machine is was running in the pic. Usually you get a buzzing sound a few clicks and either more buzzing or the circulation motor will start. The no display drives me nuts and is only for the delay feature. |
Post# 969992 , Reply# 9   11/25/2017 at 22:06 (2,341 days old) by iej (.... )   |   | |
That sounds very like the capacitor gone. Simple repair, |
Post# 971801 , Reply# 10   12/5/2017 at 20:03 (2,331 days old) by Spacedogb (Lafayette, LA)   |   | |
Hey everyone, The capacitor came in this evening. I will try and look at videos on how to repair it. Anything in particular that I need to look out for? Thanks, Blake |
Post# 971808 , Reply# 12   12/5/2017 at 21:00 (2,331 days old) by brisnat81 (Brisbane Australia)   |   | |
Be aware when you tip it onto its back that water will run out of the overflow in the bottom of the dishwasher. The only way to prevent this is to use a sponge or a towel and fully drain the sump. Otherwise you'll need a Torx headed driver to get the base plate off to get in there. |
Post# 972071 , Reply# 14   12/7/2017 at 02:19 (2,330 days old) by RichNZ (New Zealand)   |   | |
mains filter/suppression capacitor. Turn off the softener and see if you hear a buzz. |
Post# 973345 , Reply# 15   12/12/2017 at 23:17 (2,324 days old) by Spacedogb (Lafayette, LA)   |   | |
So after changing both capacitors, I still have the buzz. I have now ordered the water valve located on left side if dishwasher. I’m $250 into the machine and if this doesn’t work I will be carrying it over to the trash. |
Post# 973398 , Reply# 16   12/13/2017 at 04:51 (2,324 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
I mean, why trash such an expensive machine just because it makes a noise? As long as it runs, let it run... |
Post# 973494 , Reply# 17   12/13/2017 at 16:36 (2,323 days old) by Spacedogb (Lafayette, LA)   |   | |
Fear of the unknown is why. What if this part causes a fire? The plug is located behind the unit in Jr cabinet, so I cant unplug after each use. Also I’m in a long chain of townhomes. If My unit were to catch fire and set my neighbors home on fire I would feel terrible. |
Post# 973921 , Reply# 19   12/16/2017 at 02:15 (2,321 days old) by Spacedogb (Lafayette, LA)   |   | |
Post# 974920 , Reply# 20   12/21/2017 at 18:20 (2,315 days old) by Spacedogb (Lafayette, LA)   |   | |
Can anyone help me with these questions? Thanks |
