Thread Number: 73464
/ Tag: Ranges, Stoves, Ovens
1957 (?) Hotpoint Customline Wall Oven Hinge problem |
Post# 970144 , Reply# 1   11/26/2017 at 19:27 (2,335 days old) by rp2813 (Sannazay)   |   | |
Post# 970168 , Reply# 2   11/26/2017 at 22:48 (2,335 days old) by diesirae7 (Central Illinois)   |   | |
You'll have to get it apart and see what the issue is, some metal fabrication can make a new part. I'm making new brackets for an oven door this week, will use some steel and mig welder, some grinding to contour etc. new steel rod for hinge pins. |
Post# 970257 , Reply# 4   11/27/2017 at 12:56 (2,334 days old) by rp2813 (Sannazay)   |   | |
Post# 970272 , Reply# 5   11/27/2017 at 14:34 (2,334 days old) by customline (pennsylvania)   |   | |
I wouldn't steer you wrong. Could also be a '58 because of the black glass clock face and meat thermometer. These ovens are good every day drivers. |
Post# 970544 , Reply# 6   11/29/2017 at 07:30 (2,332 days old) by norgeway (mocksville n c )   |   | |
The hinge itself isn't the problem, I bet its the roller assembly , probably just stuck. |
