Thread Number: 73468
1-18 fill adjustment? |
Post# 970275 , Reply# 1   11/27/2017 at 15:48 (2,334 days old) by bendixmark (Winchester Mass)   |   | |
There is an adjustment screw on the water level switch to bring it higher the thing is if you do and I have tried this when the machine agitates at this level it throws water around like mad. If you had the lid up you would get drenched.It will even leak on the floor. |
Post# 970282 , Reply# 2   11/27/2017 at 16:47 (2,334 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Greg, with the 1-18 you have to remember "less is more". When I had one I started a few loads and each time decided it needed more water because I thought overfilled it with clothes. I quickly learned the roll-over is much better of it looks like it's under filled with water. Add more water and roll-over slows quite a bit.
Plus as Mark confirmed, I can only imagine how aggressively splashy it would be with the water level any higher. |
Post# 970311 , Reply# 3   11/27/2017 at 19:54 (2,334 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This is easy to do and when I got my first 1-18 I did just that and quickly learned that 1-18s have very poor turn-over with a high WL and as they drain the higher WL makes the lint redepositing problem MUCH worse, I had no problems with splashing or leaking however.
I always though that it was too bad that GM-FD did not come out with a dual action agitator for the 1-18, it could have had flip-up wings near the top of the agitator that would flip out on the down stroke and flip back in on the up-stroke to really move the clothing on these extra large tub machines.
