Thread Number: 73471
/ Tag: Modern Dryers
Advice needed please whirlpool 10kg dryer |
Post# 970208   11/27/2017 at 06:51 (2,313 days old) by Robliverpool (england Liverpool)   |   | |
Hi guys.
Not posted in a while. Picked up this dryer the other day and it won't start. There's power going into the machine. I've had a multi meter to the switches and all seems to be fine but nothing. I done a quick check to see if it had a thermal fuse but can't locate it. I've repaired 100s of dryers over the years but I've never worked on one of these. Any advice would be appreciated |
Post# 970214 , Reply# 1   11/27/2017 at 08:31 (2,313 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 970216 , Reply# 2   11/27/2017 at 08:39 (2,313 days old) by Robliverpool (england Liverpool)   |   | |
Post# 970225 , Reply# 3   11/27/2017 at 09:21 (2,313 days old) by Robliverpool (england Liverpool)   |   | |
Post# 970350 , Reply# 5   11/28/2017 at 04:49 (2,313 days old) by robliverpool (england Liverpool)   |   | |
Hi
This dryer doesn't work off a normal plug. It has to be hard wired to a 30 amp connection because of the high current using 6mm cable which is probably why they are not very common here as it would need a whole new installation were as normal UK dryers work off the 13 amp plug and can pretty much be placed anywhere |
