Thread Number: 73520
2 Speed Washers |
Post# 970931   12/1/2017 at 11:18 (2,309 days old) by chetlaham (United States)   |   | |
When did manufacturers start offering two speed washers? And why do they offer two speed washers? I ask because I have seen plenty of low end models that achieve a delicate and permanent press cycle via single speed motor. Case in point, page 15:
c.searspartsdirect.com/mmh/lis_p... |
Post# 970933 , Reply# 1   12/1/2017 at 11:32 (2,309 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 970937 , Reply# 2   12/1/2017 at 11:36 (2,309 days old) by turquoisedude (.)   |   | |
Post# 970958 , Reply# 3   12/1/2017 at 13:09 (2,309 days old) by chetlaham (United States)   |   | |
Post# 970963 , Reply# 4   12/1/2017 at 13:34 (2,309 days old) by Frigidaireguy (Wiston-Salem, NC)   |   | |
I believe Maytag was 1956 or 1957 - The first Center Dial Washer. |
Post# 970974 , Reply# 5   12/1/2017 at 14:11 (2,309 days old) by chetlaham (United States)   |   | |
Post# 971012 , Reply# 6   12/1/2017 at 18:52 (2,309 days old) by Yogitunes (New Jersey)   |   | |
Post# 971058 , Reply# 7   12/2/2017 at 02:26 (2,308 days old) by toploadloyalist (San Luis Obispo, CA)   |   | |
According to I've read in the Sears catalog collection in ancestry.com, Sears in 1955 was the very first washer brand to introduce the two-speed washers. The cycle was originally named 'MAN-MADE FABRICS'. |
Post# 971060 , Reply# 8   12/2/2017 at 02:33 (2,308 days old) by toploadloyalist (San Luis Obispo, CA)   |   | |
It was called 'MODERN FABRIC'. |
Post# 971107 , Reply# 9   12/2/2017 at 08:31 (2,308 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 971108 , Reply# 10   12/2/2017 at 08:34 (2,308 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 971110 , Reply# 11   12/2/2017 at 08:40 (2,308 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
With early semi or even fully automatic washing machines with one speed standard advice was to launder delicate and or items made from man made fibers for shorter periods of time.
If using a spin dryer you only spun for a short time. Using a washing machine with only one speed motor usually the spin cycle was a shortened version of full speed. The full speed haste in post war era in development of man made fibers for textiles meant changes were going to be needed in laundry habits. After all as the above clip makes clear; what is the point of all that "easy care" advertising if things had to be sent out to the dry cleaners? Might as well stick with wool or whatever other natural fiber. Am guessing Sears sourced that "first" washer for "man made fabrics" from Whirlpool. |
Post# 971117 , Reply# 12   12/2/2017 at 10:15 (2,308 days old) by chetlaham (United States)   |   | |
Post# 971148 , Reply# 13   12/2/2017 at 13:33 (2,308 days old) by rp2813 (Sannazay)   |   | |
Two speeds come in handy if you have certain items that will benefit from the option.
Several months ago I found the vintage Maytag I had been searching for; one that offered a slow/fast combination. I wanted this for rubber-backed throw rugs that our Affinity FL can't manage to balance, even if I put two of them in there. It will often give up after about 15 minutes of trying and not spin at all.
With the Maytag, the rugs receive a gentle wash that won't rip them apart, and a fast spin to extract as much water as possible. This process, along with hanging them to dry, makes them last a lot longer. |
