Thread Number: 73532
Chevy 350 small block V8 |
Post# 971052   12/2/2017 at 01:11 (2,334 days old) by Maytag85 (Sean A806)   |   | |
My first car is a 1986 Chevy Camaro Z28, and I am getting a Chevy 350 small block in it. Has anyone here on AW ever had a car or truck with a Chevy 350 small block? If so how reliable were they, and how easy are they to work on?
I'll put a couple of pictures of my '86 Camaro, and 350 small block. |
Post# 971055 , Reply# 1   12/2/2017 at 01:45 (2,334 days old) by sudsmaster (SF Bay Area, California)   |   | |
Well, I have a '67 Chevy van with a 283 small block. Essentially the same motor, although mine doesn't have much in the way of smog equipment (It does have an added on EGR valve). The 350 was a direct descendant of the 283, which in turn came from the 265 that first appeared in Corvette in the 50's.
These motors have a reputation for being indestructible. Plus they are so popular it's probably no problem finding parts and people to work on them.
They are also relatively easy to work on. Mine is a bit more of a challenge because of the tight confines of the '67 van doghouse - but a full size car engine bay should be much easier.
Mine wasn't running too well when I got it around 2008. After trying a lot of things, I finally adjusted the valves, and found they had not enough clearance. Once I adjusted that (again, pretty easy), it ran much much better.
There are also all sorts of mods you can do with a small block. The one I probably will eventually do is to replace the two bore carburetor with some sort of fuel injection. I'm sure yours has fuel injection already. On mine, a previous owner upgraded the points style distributor with an electronic unit,which has been problem free. The one thing I don't like about the motor is the placement of the distributor at the rear of the engine, which is a bit awkward on the van. Fortunately the electronic unit needs little to no maintenance.
Post# 971074 , Reply# 2   12/2/2017 at 05:45 (2,334 days old) by norgeway (mocksville n c )   |   | |
Are all basically the same block size, a 350 was a good powerful engine, I'm not a GM person, but my pick is a 327, 300 horsepower. |
Post# 971093 , Reply# 4   12/2/2017 at 07:08 (2,334 days old) by goatfarmer (South Bend, home of Champions)   |   | |
nice ride! I'm preferential to Pontiac myself.....
Post# 971164 , Reply# 6   12/2/2017 at 16:31 (2,333 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
has a 327 4 bbl 250hp, which directly preceded the 350 which was introduced in the Camaro and was replaced the 327 by '69. Ours has never been touched and after 50 years still just purrs. I'm in total agreement with those who call the Chevy small block one of the 2 or 3 greatest engines of all time, if not THE greatest. It came in many versions from the 1955 265 cu to the early '70s 400 cu in. small blocks and all were great...you can still by a new crate motor from GM for about 1500$, hard to go wrong!
Post# 971344 , Reply# 8   12/3/2017 at 19:20 (2,332 days old) by sudsmaster (SF Bay Area, California)   |   | |
Perhaps the other American post war car engine that rivals the Chevy small block in reliability is the Chrysler Slant Six.
The main drawback of the /6 is that it's never been a favorite of hot rodders, so there isn't the plethora of performance enhancing options that there are for the Chevy or V8's in general. It's also a long stroke motor so it can't be run to as high revs as an oversquare motor could. But it's very smooth and torquey, and can last virtually forever.
Post# 971377 , Reply# 9   12/3/2017 at 22:53 (2,332 days old) by StrongEnough78 (California)   |   | |
The Chevy 350 small block is the easiest to work on, most versatile and run damn near forever if taken care of. It's probably the most popular engine GM put out. There are many different performance parts both OEM and aftermarket for these engines to make the engine as economical or as powerful as you want. The possibilities are endless.
Post# 971396 , Reply# 10   12/4/2017 at 01:38 (2,332 days old) by tolivac (greenville nc)   |   | |
Remember Chevy 350 motors used a lot as inboard and inboard-outboard boat motors.Was a marine version.Seems like that motor was used in other things besides cars. |
Post# 971420 , Reply# 11   12/4/2017 at 08:15 (2,331 days old) by sudsmaster (SF Bay Area, California)   |   | |
I don't think the 350 has seen much duty in fork lifts and such, though.
I know the /6 predecessor, the Chrysler inline flathead six, was used extensively in industrial applications. Probably the /6 as well, since it's a simple torquey low vibration motor (all inline sixes have perfect primary balance, unlike fours or eights).
