Thread Number: 736
Kenmore front loader question |
Post# 50921   12/13/2004 at 18:38 (7,067 days old) by pumper (SE Wisconsin)   |   | |
At the end of the final spin, the motor quit and the timer doesn't advance. It fills and drains but doesn't tumble. The troubleshooting sheet said to check the fuse on the speed control board. It is white. Is that a bad or good fuse? It says if the fuse is bad to replace the board. I checked the connections and everything is tight. I don't have anything to check voltage so any ideas are appreciated.
