Thread Number: 73707
Basket Drive Rebuild |
Post# 973456 , Reply# 1   12/13/2017 at 11:07 (2,317 days old) by swestoyz (Cedar Falls, IA)   |   | |
Once the set screw is removed the hub should lift off the spin tube, but I imagine there is some debris that may be interfering with the removal. I'd continue to tap lightly around it to break up anything that may be interfering and continue to try and remove the top of the brake. Here's a post where I documented the rebuilding of a basket drive...
www.automaticwasher.org/cgi-bin/T... Ben |
