Thread Number: 738
Asko washer help/advice |
Post# 50926 , Reply# 1   12/13/2004 at 19:21 (7,066 days old) by partscounterman (Cortez, Colorado)   |   | |
I just blew hard into the drain hose while the pump was running. Guess that little tiny impeller is the whole pump after all. Please keep your comments to this post "G" rated. I Know where some of you might go with this ; ) |
Post# 50947 , Reply# 3   12/13/2004 at 21:42 (7,066 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 50955 , Reply# 4   12/13/2004 at 22:52 (7,066 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 50966 , Reply# 5   12/14/2004 at 05:53 (7,065 days old) by wringingwet (Walterboro South Carolina)   |   | |
Post# 51081 , Reply# 8   12/15/2004 at 00:48 (7,064 days old) by laundromat (Hilo, Hawaii)   |   | |
your best bet is to just order and replace the old pump with a new one.They run about $45 at the parts places and will stop any nightmares or headaches from happening.I have had quite a few of them myself and the worst ones were an all electronic control pair I found in a dumpster at Celebration near Disney.Both boards needed replacement and cost about $300 each.However,I squawked and moaned enough to get Assko :) to over ride the cost.The models were less than 2 years old and other than bad boards,they were in mint condition.My friend,Deborah Morse in Atlanta still has them and has had no problems since 1998.The set I kept was newer and performs well.The dryer was fine but the washer would not pump out and the problem began from not having the trap cleaned out.There was so much s--t there that rather than enen try to clean out all the lint and scum from the trap through the drain hose assembly,i bought a new pump and drain hose and flushed out the rest of the drainage area during the repair.It works great now and even though the cycle takes for f---g ever,it does a fabulous job and a 1700 rpm spin really gets the clothes quite dry.The 200 degree FT.wash makes my socks so white you need sunglasses to put them on!!!
