Thread Number: 73808
Speed Queen vs GE |
Post# 975028   12/22/2017 at 16:26 (2,315 days old) by chetlaham (United States)   |   | |
Post# 975092 , Reply# 1   12/23/2017 at 05:59 (2,314 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Skip the first 25 minutes of this review and probably the whole thing, We all know that the SQ is the better built washer and will outlast 2 or 3 of these GEs, however the GE is a better performer in most ways, better water extraction, will get more lint and heavy dirt out of clothing, balances better in spin, better and more versatile cycle selections and quieter in operation.
If I was going to have one of these two machines in my laundry room it would be the GE, but if I was recommending one of these for a customer that primarily wants durability [ and is not into washers ] it would be the SQ, however I plan on not having either one in my laundry room as I only have room for about 10 AWs and neither of these make the top 10 list.
I don't think much of this guys mechanical ability's or his analysis of the two machines, hes even too lazy or stupid to reverse the dryers door to open correctly for his home, LOL.
Post# 975098 , Reply# 2   12/23/2017 at 06:55 (2,314 days old) by chetlaham (United States)   |   | |
Post# 975118 , Reply# 4   12/23/2017 at 08:12 (2,314 days old) by chetlaham (United States)   |   | |
"There are my reviews like these on youtibe, and barely any are helpfull at all."
Oh the irony- I could judge you by the spelling hear alone. But I do not as I know you are a very smart person- and we all make mistakes including myself. In any case I think the guy does a good enough job- people clearly see the SQ is built like a tank. |
Post# 975173 , Reply# 6   12/23/2017 at 14:27 (2,314 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 975176 , Reply# 7   12/23/2017 at 14:50 (2,314 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 975215 , Reply# 8   12/23/2017 at 18:54 (2,314 days old) by chetlaham (United States)   |   | |
@Henene: Exactly, hence why your spelling is a none issue. I could find strengths and weaknesses in every member at no fault of there own. Everyone is learning and improving- it never stops. If this is the guys first time ever taking apart a washing machine of course he will not know the correct definitions or what a pressure hose is. Many of us learned the correct terminology after hours and hours of reading service manuals and repairing machines. Learning how a washer works in detail is basically obtaining a micro college degree- an era of technology all on its own. The guy could even be IT, skilled trades, perhaps even a mechanical engineer for all we know, but since its not his era of expertise he is left guessing. Assumption often leads us to be way off.
For example, I know utility line workers who can do everything from secondary networks up to new build 500kv, but can not wire a home correctly or to code simply because its so different from their normal line of work in every single regard. Good example: for some utilities green is actually a phase conductor- to the rest of us we know green is ground- so when a guy accidentally slips up calling a ground a "hot" wire I'm sure he will seem like the last person having anything to do with electricity. As for the dryer door, its not reversed on my dryer either even though it should have been a long time ago. There are time constraints (yes I know its a 5-10 minute job) and the fact I am not sure if I will be moving soon or not. No point in swapping the door if the new property requires a swap back. The relay- yes that would be a centrifugal switch- but again, if the guy has never seen a tech sheet to washer, it would be easy to assume relay. Overall the purpose of that video is to show people a side by side of the best against the worst. Yes there was a SQ vs Maytag, but not a SQ vs GE. |
