Thread Number: 73886
/ Tag: Modern Dryers
Maytag Performa Ultra Care 2 LAT2500AAE |
Post# 976026 , Reply# 2   12/29/2017 at 16:10 (2,307 days old) by coldspot66 (Plymouth, Mass)   |   | |
LAT2500AAE is a dependable care washer...not a Norgetag or Searcy platform. |
Post# 976123 , Reply# 4   12/30/2017 at 11:42 (2,306 days old) by Yogitunes (New Jersey)   |   | |
I have had a few of the NorgeTag units, Atlantis to be exact, preferred the stainless tub units....and see nothing wrong with them, super capacity units, heavy duty, effective washing and rinsing....pumps were a usual weak spot....with proper care, their really nice machines.....
in any case..... according to this link, the trans is available as a full replace/repair kit....everything you need in one package... CLICK HERE TO GO TO Yogitunes's LINK
Post# 976141 , Reply# 5   12/30/2017 at 13:09 (2,306 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Jen This is an easy to diagnose washer but it might be tough to fix, and it sounds like you may have several problems so with out videos pictures and more description I am not going to get into guessing what is wrong, If you really want to fix it I would get an experienced repair person to give it a good looking over unless you want get the manual and spend a lot of time learning and experimenting with this machine.
Post# 976222 , Reply# 7   12/30/2017 at 22:35 (2,306 days old) by speedqueen (Metro-Detroit)   |   | |
A new transmission does seem in order. These machines spin the whole transmission with the tub when spinning. The gearbox is not transmitting any movement through the gears during a spin henceforth why the spin cycle still works and agitation doesn't.
During agitation the transmission is held by the tub brake and the internal mechanism is creating the back and forth agitation motion. During spin, the motor goes the opposite direction and the transmission pulley locks with the transmission housing and both the housing and tub rotate in unison. In other words the spin function doesn't rely on the transmission for anything but acting as the driveshaft. |
Post# 976411 , Reply# 8   1/1/2018 at 09:03 (2,304 days old) by vacerator (Macomb, Michigan)   |   | |
is a dependable care transmission. The "Performa" gear case looks rather like a thick saucer disk. |
Post# 976420 , Reply# 9   1/1/2018 at 09:51 (2,304 days old) by DADoES (TX, U.S. of A.)   |   | |
