Thread Number: 73893
/ Tag: Modern Dishwashers
GE Profile Dishwasher PDW8200 SERIES service manual |
Post# 976150 , Reply# 1   12/30/2017 at 15:05 (2,307 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Second search result from the top for me: www.manualslib.com/manual... |
Post# 976152 , Reply# 2   12/30/2017 at 15:18 (2,307 days old) by johnb300m (Chicago)   |   | |
That rubber tube that disintegrated is part of the main boot assembly. Without it, the machine washability will suffer. Any soils collected in the fine filter will exit through the defective tube and back into the water.
Without pictures I surmise you will need a whole new sump boot for the Triton XL series. It’s not expensive but it involves full disassembly. |
Post# 976545 , Reply# 4   1/1/2018 at 23:27 (2,305 days old) by Johnb300m (Chicago)   |   | |
Yep, an all new sump boot with integrated filter drain tube should perk ya right up.
These are GOOD machines. Sadly they got hit hard for several years when detergent makers were struggling to reformulate after the phosphate ban. They should be ok now with high quality Cascade or Finish tabs. Once you got that new boot, you'll be back in business! |
