Thread Number: 73935
/ Tag: Ranges, Stoves, Ovens
Frigidaire Electric Range, Model RS-35 |
Post# 976805 , Reply# 1   1/4/2018 at 05:56 (2,297 days old) by norgeway (mocksville n c )   |   | |
I have a 52 that is slightly different, great baking ranges, you will love it |
Post# 976813 , Reply# 2   1/4/2018 at 07:49 (2,297 days old) by mikael3 (Atlanta)   |   | |
I love and adore my ’54. I have an RT-38—R means range, and T means 1954. S means 1953.
In ’53, Frigidaire had two “chassis” for the 30″, the older 35 model and the newer 38 model.
Other people here know more about these than I do. |
Post# 1163957 , Reply# 6   11/15/2022 at 11:17 (521 days old) by Yesterdog (Spring hill)   |   | |
I just bought the same stove,but the wiring diagram is missing. Any chance you could share a picture and also share where you purchased the manual? Many thanks! |
Post# 1163961 , Reply# 7   11/15/2022 at 12:11 (521 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I would try a vacuum cleaner and then a damp cloth with a little bit of detergent or other cleaners, be very careful about vinegar it can ruin the painted surface and doesn’t do much anyway.
The inside of the oven should be wiped out with a damp cloth maybe even a fairly wet cloth if there’s any residual oven cleaner in any cracks and crevices, oven cleaner can really make a smell if it’s not all rinsed away. You can use a small amount of vinegar in the water to wipe out the inside of the oven since the inside of the oven is porcelain enamel. John L |
Post# 1163968 , Reply# 9   11/15/2022 at 13:33 (521 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Don’t let large areas of the burner glow red hot for extended periods of time.
When using high or medium high setting if more than a small area the burner is glowing red hot the burner or the pan you’re using is too warped and you need to turn down the heat or get a different pan, in some cases the burner needs to be straightened or replaced as well. John L |
