Thread Number: 73951
/ Tag: Detergents and Additives
Detergent use fine tuning |
Post# 976986 , Reply# 1   1/5/2018 at 13:58 (2,295 days old) by panthera (Rocky Mountains)   |   | |
Post# 977001 , Reply# 3   1/5/2018 at 16:26 (2,295 days old) by Frigilux (The Minnesota Prairie)   |   | |
The softness/hardness of your water comes into play, as well. I've had mechanically softened water all my life--in other words, very soft--and dosages can be cut to almost half for most loads. My self-dosing 2015 Maytag front-loader delivered an amazingly parsimonious dose of liquid Tide Ultra Stain Release and results were pristine. I realized I'd been overdosing detergents for years.
Post# 977066 , Reply# 4   1/5/2018 at 23:56 (2,295 days old) by Imperial70 (MA USA)   |   | |
I have been using a coffee scoop (two tbsp, I think) of detergent per load with excellent results. Hot water for whites and heavy colors. Warm water for delicate colors. I have a GE PFWS4600 front loader. |
Post# 977148 , Reply# 5   1/6/2018 at 13:42 (2,294 days old) by kb0nes (Burnsville, MN)   |   | |
I watch (and feel the water for slipperiness) during the wash cycle and dose accordingly. This is more indicative of proper detergent concentration. While I don't want to see lasting foam in the sink, remember that the action of the drain pump is likely to over froth the water so it is likely you may some minor sudsing.
Post# 977843 , Reply# 6   1/11/2018 at 05:43 (2,289 days old) by Tomturbomatic (Beltsville, MD)   |   | |
And some detergents, especially liquids, keep on sudsing through the rinses sometimes even more so than in the wash. |
Post# 977887 , Reply# 9   1/11/2018 at 11:00 (2,289 days old) by Rolls_rapide (.)   |   | |
Oops, left out the link. The pdf download of manual is on the extreme right-hand column, coloured in red text. CLICK HERE TO GO TO Rolls_rapide's LINK |
Post# 977925 , Reply# 10   1/11/2018 at 19:31 (2,289 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
"- abundant foam: This is often due to the
anionic surfactants found in the detergents which are hard to eliminate from laundry. In this case, do not re-rinse to eliminate these effects: it will not help at all. We suggest conducting a maintenance wash using a proprietary cleaner." Have found this to be true. After several rinses if froth is still visible best to leave well enough alone and move onto drying. Next time things are laundered use less (or nil) detergent as the residue will provide some cleaning action. What the anionic surfactants need isn't rinsing to remove IMHO, but oils/something for them to work upon. That is what they are designed to do. It also explains why if one adds fabric softener or anything else with a oil/fat base the froth tends to go away. Back when purchased first front loader (Malber) made the mistake of using a full (sample) packet of a new Tide liquid. It created froth for ages that simply wouldn't rinse away. Contacted service department as was instructed to remove washing, pour a small amount of olive or some other oil into tub, then restart washer for a full cycle. Suds at once cleared and that was an end to things. Today of course one uses a silicone based anti-foaming product, but the basics remain same. If you read the "troubleshooting" pages for many front loaders sold today (including IIRC even Miele) where the question of "foam still visible in/after final rinse" comes up; advice given is that does not mean things have not been properly rinsed by machine, but the properties of certain detergents (liquids) cause the issue. If one does not wish to see such froth, it is recommended to switch to powders. |
Post# 978006 , Reply# 12   1/12/2018 at 12:15 (2,288 days old) by SudsMasteR (SF Bay Area, California)   |   | |
Me mum was always grousing about how detergent mfg's would recommend way too much product, intimating that they were trying to rip off customers. We also were the only family I knew in the 1950's that had a front loader (Bendix) so she kept a sharp eye on over-sudsing.
I think the reason the mfg's recommend what can be an excess is not quite so negative, as it's difficult to know all the variables in advance: tub size, water volume, laundry weight, soil level, water hardness, type of soil, etc. So the detergent mfg's tend to err on the side of excess, so that they don't get more complaints that their product doesn't clean well enough. That said, I also don't like to see suds in the final rinse. Sometimes I'll run four additional rinses for a finished load if there's a lot of excess suds. There is a point of no return, however, as some tap water may be heavy in foam causing components that will result in what looks like suds in the final rinse. Or, the machine may have excess detergent caked into its innards, and that can take a while to flush out. Oh, and Mum used to refuse to go for the "free towel in every box" promotions. She said towel took up space that should be for detergent... She was from a frugal generation. |
