Thread Number: 74036
/ Tag: Vintage Dishwashers
KUDS-23 timer question |
Post# 978126   1/13/2018 at 12:47 (2,288 days old) by barcoboy (Canada)   |   | |
I had just started a Pots & Pans cycle of my KUDS-23, and realized a bit later that I had forgotten to add something. By this time, the cycle had progressed to the wash after the initial heating period, so I waited until mid way through the wash once the reheat period had started. I opened the door, and was surprised to hear the timer motor continue to run. I added my items and closed and re-latched the door, and tried opening it again a few times, and each time the timer motor continued to run. I believe everything switch wise is fine, as the "Heating Water" light goes out when I unlatched the door, I can hear the interlock switch click when I pull the door open slightly after unlatching it, and if I try to latch the door when it is not closed, the progress lights do not turn on. Once the heating period was over, the wash continued, and now when opening the door again, the timer motor does stop. Should I be concerned about this, or is this normal behavior?
