Thread Number: 74110
/ Tag: Modern Dishwashers
Not quite a bob load |
Post# 978900   1/18/2018 at 21:21 (2,282 days old) by Spacedogb (Lafayette, LA)   |   | |
Tonight I made Ribs, Scalloped Potatoes, and Mac and cheese. Decided to load into the Miele along with plates and other glassware. Pot &Pans cycle with minimal detergent. Let’s see what the Miele can or can’t do...... |
Post# 978985 , Reply# 1   1/19/2018 at 12:49 (2,282 days old) by bewitched (Italy)   |   | |
what did it do? |
Post# 979067 , Reply# 2   1/19/2018 at 21:13 (2,281 days old) by Spacedogb (Lafayette, LA)   |   | |
Pretty good for the small amount of detergent and the horrible loading I did. |
Post# 979096 , Reply# 3   1/20/2018 at 01:40 (2,281 days old) by jkbff (Happy Rock, ND)   |   | |
Post# 979101 , Reply# 4   1/20/2018 at 02:21 (2,281 days old) by bewitched (Italy)   |   | |
i would say you got very good result. what model do you have? i have a G 6900 Sci and it never disappointed me in washing everything perfectly
Post# 979177 , Reply# 5   1/20/2018 at 15:42 (2,281 days old) by Spacedogb (Lafayette, LA)   |   | |
G5105 Futura Crystal |
Post# 979199 , Reply# 6   1/20/2018 at 17:20 (2,281 days old) by jkbff (Happy Rock, ND)   |   | |
That ring around the pyrex and the chunks on the sheet pan shouldn't be there though.
I've gotten very comfortable with my G2020's results, but I did go in and raise the wash temp and added an interim rinse. On pots and pans on a crystal, the chunks shouldn't be there if all three arms were working properly and that ring should be gone if it was hit with enough water that was up to temp. Would detergent really make that much of a difference? I guess I always stuff my machine full and I use Miele tabs. |
Post# 979223 , Reply# 7   1/20/2018 at 19:20 (2,280 days old) by Spacedogb (Lafayette, LA)   |   | |
1 piece of chocolate sheet cake added mid cycle. Small amount of detergent and express cycle with turbo setting. Jkbff how do I increase temp and add rinse? Also excuse the dirty dishwasher front. |
Post# 979230 , Reply# 8   1/20/2018 at 19:37 (2,280 days old) by jkbff (Happy Rock, ND)   |   | |
Post# 979234 , Reply# 9   1/20/2018 at 19:58 (2,280 days old) by Spacedogb (Lafayette, LA)   |   | |
Email is current. Back half of basket is out. I got the machine for free on Craigslist. The softerner reactivation valve buzzes loudly (I replaced it and still buzzes). So the original owners were throwing it out. |
Post# 979235 , Reply# 10   1/20/2018 at 19:59 (2,280 days old) by Spacedogb (Lafayette, LA)   |   | |
Latest results just a little bit of cake bits left around and on the glasses, silverware basket, and roof. |
Post# 979312 , Reply# 12   1/21/2018 at 11:03 (2,280 days old) by Spacedogb (Lafayette, LA)   |   | |
I use Cascade Complete Powder. I also wanted to try with express turbo because I like the short was cycle. This machine has an EXTREMELY long run time on pots and pans or normal wash. |
Post# 979416 , Reply# 13   1/22/2018 at 09:52 (2,279 days old) by jkbff (Happy Rock, ND)   |   | |
I'm sending you an email but let me ask this, the 30-45 minutes the turbo option saves you, how much time and additional water is spent/used rewashing and drying the dishes?
I think this generation uses slightly more water than the current 6000 Generation machines, but I know the turbo option in the older units hinders wash performance. That being said, if you used the turbo wash on both sets of pictures, that absolutely explains the wash results. There is a reason for the lengthy times. Any wash-ability or drying complaints I've received from customers have all lead to someone pushing the turbo button. Turbo can't handle burned on or heavily soiled. |
Post# 979420 , Reply# 14   1/22/2018 at 11:14 (2,279 days old) by Spacedogb (Lafayette, LA)   |   | |
Only used turbo wash and express with that piece of cake. The Corning dish and baking sheet were done using pots and pans without turbo |
Post# 979449 , Reply# 15   1/22/2018 at 13:53 (2,279 days old) by jerrod6 (Southeastern Pennsylvania)   |   | |
I use Finish Quantum tabs for burned or stuck on food. Tabs may give a better result on burned on food than any type of powder. |
Post# 979451 , Reply# 16   1/22/2018 at 14:01 (2,279 days old) by Spacedogb (Lafayette, LA)   |   | |
I use the built-in water softener and tabs cause a major oversuding. I haven’t had the suds condition with the powder. |
Post# 979456 , Reply# 17   1/22/2018 at 15:08 (2,279 days old) by jkbff (Happy Rock, ND)   |   | |
Post# 979470 , Reply# 19   1/22/2018 at 18:24 (2,279 days old) by jkbff (Happy Rock, ND)   |   | |
Post# 979474 , Reply# 20   1/22/2018 at 18:25 (2,279 days old) by Spacedogb (Lafayette, LA)   |   | |
It only buzzes when it’s supposed to operate. I’ve changed it and it still buzzes and I think it also is what causes cavitation |
Post# 979517 , Reply# 21   1/22/2018 at 22:46 (2,278 days old) by Spacedogb (Lafayette, LA)   |   | |
JKBFF, I can’t thank you enough for the programming instructions. If nothing else I was able to program the dishwasher so I can see the time left. |
Post# 979870 , Reply# 24   1/25/2018 at 10:37 (2,276 days old) by jkbff (Happy Rock, ND)   |   | |
