Thread Number: 74204
/ Tag: Modern Dryers
Miele T1515 dryer ducting |
Post# 979946 , Reply# 1   1/25/2018 at 21:06 (2,275 days old) by enduring (Iowa)   |   | |
I just looked up the T1515 duct length recommendation in the manual online. IT states the duct can be max at 66'. That is longer than I thought, is that right? If so, than I don't need a dryer fan. |
Post# 980010 , Reply# 2   1/26/2018 at 14:03 (2,275 days old) by enduring (Iowa)   |   | |
Anyone want to share their thoughts on ducting these machines? |
Post# 980025 , Reply# 3   1/26/2018 at 16:13 (2,275 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
How far are you having to run ducting? Do you plan on running them simultaneously? There are back-flow preventers for vents, relatively inexpensive at Lowes. This would allow you to join them via a "Y" connector into one outlet to the outside but it's probably not a good idea to run them at the same time as the volume of air may be too great for the 4" venting.
I've often thought about this problem in my own basement, using a larger 6-8" duct length and using a booster fan at the end to keep the exhaust air moving smoothly. The back flow dampers would help with warm, moist air pushing back into the non-running dryers. CLICK HERE TO GO TO gansky1's LINK
Post# 980028 , Reply# 4   1/26/2018 at 16:44 (2,274 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 980043 , Reply# 6   1/26/2018 at 18:57 (2,274 days old) by iej (.... )   |   | |
You shouldn’t need any in-line fans and you may mess up the dryers’ airflow by forcing air through them. You should have a detailed ducting guide in the manual, including how to calculate bends and so on.
Post# 980044 , Reply# 7   1/26/2018 at 18:59 (2,274 days old) by iej (.... )   |   | |
Post# 980185 , Reply# 9   1/28/2018 at 02:30 (2,273 days old) by askolover (South of Nash Vegas, TN)   |   | |
If needed, there are a few. I don't know how much you would want to spend.
Tjernlund is over $250
www.hvacquick.com/products/reside...
Fantech is cheaper, but I don't know if it's better. www.hvacquick.com/products/reside... |
