Thread Number: 74308
Speed Queen AWNE92SP113TW01 hot water inlet filter? |
Post# 981092   2/3/2018 at 08:29 (2,244 days old) by jp10558 (Southern Tier, NY, USA)   |   | |
Does the above SQ have a filter for incoming hot water that can get clogged? If so, where is it (Hopefully I could get to it by just taking off the house connection and clean it at the front of the hose)... |
Post# 981098 , Reply# 1   2/3/2018 at 11:22 (2,244 days old) by dylanmitchell (Southern California)   |   | |
Post# 981121 , Reply# 2   2/3/2018 at 15:46 (2,244 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It has one in the inlet to the inlet valve and it may have one in one end of the inlet hose, if you are having a lot of problems in your home with clogged aerators on faucets and shower heads you may want to check these screens, but keep in mind that the hot water fill on this Newer SQ washer is only about 1/3 of the fill rate for the cold fill, so there probably is nothing wrong with the machine.
