Thread Number: 74378
/ Tag: Classified Ad Finds
72 Kenmore Washer $30 Sterling Heights |
Post# 981725   2/7/2018 at 10:47 (2,241 days old) by mopar65 (Almont MI)   |   | |
Post# 981726 , Reply# 1   2/7/2018 at 10:48 (2,241 days old) by turquoisedude (.)   |   | |
Post# 981733 , Reply# 2   2/7/2018 at 11:31 (2,241 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 981742 , Reply# 3   2/7/2018 at 12:18 (2,241 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 981766 , Reply# 4   2/7/2018 at 14:08 (2,241 days old) by speedqueen (Metro-Detroit)   |   | |
Post# 981785 , Reply# 5   2/7/2018 at 15:31 (2,241 days old) by Yogitunes (New Jersey)   |   | |
I think this is one of those rare setups that SudsSave every time from the Normal cycle....there was no switch to select 'drain' or 'save'
if you wanted to save the suds, you placed a plug in the drain, the timer has the marking for 'return suds'....all wash water emptied through the long hose... all rinse water goes out the other hose..... |
Post# 981788 , Reply# 6   2/7/2018 at 15:52 (2,241 days old) by extmaxspin (St Charles MI)   |   | |
Martin,
You're correct on the auto suds save. I have a 1968 600 series that is the same way. Normal and Delicate drain the wash water via the suds hose--there is no option to turn it on or off. Fortunately now I have a laundry tub to drain it into. Before moving, I had it set to drain suds into a large tote. If I didn't want to reuse it, I either had to pump it back in then drain it out via a rinse drain (which WAS kind of fun though), or move the timer to drain the wash water via a rinse (or PPWW cycle) drain. |
