Thread Number: 74397
/ Tag: Modern Dryers
Drying times? washer-dryer combo |
Post# 981989 , Reply# 1   2/9/2018 at 05:20 (2,267 days old) by retro-man (- boston,ma)   |   | |
Drying time and a small amount of moisture would not be an issue, but the dust lint problem would make me avoid said purchase. I do not want to have to clean up after a washer and dryer. Jon |
Post# 982103 , Reply# 2   2/9/2018 at 23:42 (2,266 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 982123 , Reply# 4   2/10/2018 at 04:10 (2,266 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 982126 , Reply# 5   2/10/2018 at 05:42 (2,266 days old) by retro-man (- boston,ma)   |   | |
Well if the amount is like you said then that would not be that bad. Would take it under consideration if this was the case. Would be interesting to see the unit. Jon |
Post# 982428 , Reply# 8   2/12/2018 at 02:00 (2,264 days old) by mieleforever (SOUTH AFRICA)   |   | |
If I can add something why not try using a heatpump condensor so that the condensor can be cooled by the waste product in the cycle of the heatpump thereby reducing the amount of water that is used to cool the condensor. Or would it be cost prohibtive? Regards |
Post# 982434 , Reply# 9   2/12/2018 at 02:49 (2,264 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
10% vent does not only mean some dust blown into the living space, but also humidity. That is ok in a dry climate, but in a humid climate that would be a big no. Overhere condenser dryers are tested on how well sealed they are, a 10% vent would score absolutely bad on that aspect. Place such a machine in a small bathroom and your mirrors will fog up.
Also humidity and lint blown into the living space is a reason not to buy such a machine for people with asthma or other breathing problems. |
Post# 982561 , Reply# 11   2/13/2018 at 00:07 (2,263 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
I tested it in the climate chamber. The humidity expelled to the ambient is minimal and unnoticed. If you place it in a closed bathroom it is not enough to fog the mirrors. |
Post# 982563 , Reply# 13   2/13/2018 at 00:14 (2,263 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Moisture doesn't blow that much (as well as lint) because of the condensing system. And the lint is washed away on the next wash cycle. The blower is also washed every time the washer fills and it spins dry on the first seconds of the drying. |
Post# 982566 , Reply# 15   2/13/2018 at 00:30 (2,263 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Oh, and it has a spray rinse. |
Post# 982697 , Reply# 16   2/13/2018 at 19:44 (2,262 days old) by speedqueen (Metro-Detroit)   |   | |
Post# 982735 , Reply# 18   2/14/2018 at 02:53 (2,262 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
"Could the machine also wash at near 1/2 the door if, say, the user selects an option to do so (or an easy adjustment/modification for AWers)?" It does. Actually the user can select 3 water levels: "Eco-nazi", "Common-sens"e and "I want to use all the water in the world and make the clothes look like esther williams during the wash or the rinse" |
Post# 982738 , Reply# 20   2/14/2018 at 03:13 (2,262 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 982739 , Reply# 21   2/14/2018 at 03:28 (2,262 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
The molds already exist, it's impossible to make new molds because the cost is absurd. |
