Thread Number: 74430
/ Tag: Wringer Washers
anyone have a pump for my dexter quicktwin? |
Post# 982318 , Reply# 1   2/11/2018 at 14:28 (2,258 days old) by Yogitunes (New Jersey)   |   | |
if you can't find a replacement, many have installed an electric pump in place, would be simple to install a switch and tap into the power...
most times the hole in the lid was to hold/store the drain hose...almost every wringer had a setup to wrap the cord and hold the hose..... not sure what you mean by re-using/returning the suds back to the machine....most times the suds are returned to the machine by the pan under the wringer.... got to use one of these at an Aunt's house, first time ever using a wringer, placed in front of a double laundry tub, and you can kick out some serious laundry in no time... |
