Thread Number: 74487
Liquid or powder? The saga of the suds lock........ |
Post# 982800   2/14/2018 at 15:43 (2,255 days old) by robbinsandmyers (Conn)   |   | |
Ive been using liquid Tide since getting my A407 a few years ago as Its been cheap at $9.00 a bottle and I like the smell. I just bought the same sized bottle of Persil ($16.99!!) so we'll see how that does. My issue is I have to use very little detergent or the machine suds locks in the rinse spin. Im hoping Persil is better for that but Ive also heard powdered detergent doesnt suds as bad?? If so should I switch to powdered Tide? Im not sure if the long travel or height of the stand pipe is whats doing it.
Post# 982810 , Reply# 1   2/14/2018 at 17:01 (2,255 days old) by Gyrafoam (Wytheville, VA)   |   | |
It takes a lot of detergent to suds lock a Maytag these days. Back before the HE detergents arrived it was easier. Maybe your water is soft and you can use less detergent. Your Maytag should be able to completely drain the tub in less than 60 seconds. |
Post# 982813 , Reply# 2   2/14/2018 at 17:38 (2,255 days old) by robbinsandmyers (Conn)   |   | |
Well my drain hose is kinda long and the stand pipe is pretty high. The machine empties the water pretty normal but takes longer to get up to spin speed at times I think. What happens is as soon as the rinse comes on I can hear it foaming up in the outer tub and it slows right down and doesnt recover even after the rinse water stops. It just slogs all that water around slowly. However if I stop the machine and restart it then it will pump all that rinse water out but by that time the spin cycle only has another 60 seconds left top. I'll try and take a pic of the machine to stand pipe location to give a rough idea.
Post# 982862 , Reply# 4   2/14/2018 at 21:15 (2,255 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
Post# 982864 , Reply# 5   2/14/2018 at 21:22 (2,255 days old) by speedqueen (Metro-Detroit)   |   | |
Post# 982874 , Reply# 6   2/14/2018 at 23:05 (2,255 days old) by Stan (Napa CA)   |   | |
Powder while cleaning very well gave me a lot of suds. Regular Tide powder dose not.
Since you've been using liquid detergent..you might have a little build up in the machine? You might fill the machine with hot water, wait for agitation, then add a cup or two of just washing soda (No clothes) let it agaitate for 5 min, stop it let sit 15 min to loosen whatever buildup might be there, then spin it out and rinse with hot water. If there is a build up, the soda will break it loose and youl see suds (even though you didn't ad detergent) Helps clear the pump. Can't hurt to clean it out, the see how it's acts HTH. |
