Thread Number: 74525
1970 Maytag A806 - excessive vibration |
Post# 983270   2/18/2018 at 14:56 (2,230 days old) by AtomicT (Middletown, NY)   |   | |
Some of you recall, I joined this group a couple years ago, and was able to get a Maytag A806 pair. I did some very minor work to them, and put the washer into service. We have a Maytag 600 series from the 80s that we like, and have the 806 dryer sitting on the side as standby when the time comes.
Well, since then we’ve had two kids, then my mother and father-in-law moves into the house with us. So for about four years, the 806 has been doing 2 to 4 loads of laundry every day, only with a break here or there. In the past month it started really getting some excessive vibration in the spin cycle. It also started making a sound whenbfirst starting the spin cycle, kind of like a rubbing sound. I thought it was unbalanced, and I checked it. While it was slightly out of balance, it made no difference on the next load. But the surprising thing was, while I was balancing it, I noticed a small film of oil on the underside of the washer on the perimeter edge. So I assume it’s being flung off by force during the spin cycle. Oil on the belts, could be the cause of that sound? Inside the main housing all looks fine. So what is it guys? Am I near the end, or is it just the main bearing, or do I need to rebuild the transmission. I don’t really have any clue how to diagnose it, but if I know what to do, I’m pretty mechanically inclined to fix it. |
Post# 983272 , Reply# 1   2/18/2018 at 15:18 (2,230 days old) by norgeway (mocksville n c )   |   | |
With every Maytag I ever used, they sling oil, it gets under the feet and then it walks all over. |
Post# 983278 , Reply# 4   2/18/2018 at 15:51 (2,230 days old) by AtomicT (Middletown, NY)   |   | |
I grabbed the agitator and it won’t turn. That’s bad right?
I know I’ve seen the threads here before on how to work through the repair. What’s the parts list? What’s the ballpark price range? My family loves this machine and it’s obvious cool factor. I moved the machine out and cleaned around. There was no oil on the floor where the feet were. |
Post# 983281 , Reply# 5   2/18/2018 at 16:20 (2,230 days old) by good-shepherd (New Jersey)   |   | |
No. The whole tub should move easily, not the agitator. See link below, although for later models with the plastic tub cover. Parts list and numbers are in the link for the tub bearing replacement. |
Post# 983282 , Reply# 6   2/18/2018 at 16:20 (2,230 days old) by rp2813 (Sannazay)   |   | |
The agitator isn't supposed to turn when the machine isn't running. I think what GS meant is to see if you can use the agitator to tip/tilt the tub from side to side or in a circular motion. The tub itself won't turn, but the whole tub should exhibit some wiggle room.
I'm interested in what the remedy might be. I have a 1987 A712 that makes a rumbling sound at top spin speed accompanied by a bit of vibration, but behaves normally otherwise. |
Post# 983283 , Reply# 7   2/18/2018 at 16:24 (2,230 days old) by good-shepherd (New Jersey)   |   | |
Tub bearing service video: |
Post# 983430 , Reply# 9   2/19/2018 at 16:10 (2,229 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 983468 , Reply# 10   2/19/2018 at 18:50 (2,229 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Reply #5 above shows how to replace them, the problem is if the aluminum damper has gotten scored from wearing on the steel base-plate you need to also replace the aluminum damper to make a lasting repair.
This problem and transmission top shaft seizure are the two main reasons that we advise our customers to stop repairing a MT washers, of course both of these problems can still be repaired but few customers will put over $400 in a machine that is over 25 years old.
