Thread Number: 74532
/ Tag: Vintage Dishwashers
1973 KDS 17 makes terrible squeal when filling |
Post# 983315 , Reply# 1   2/18/2018 at 19:57 (2,251 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 983319 , Reply# 2   2/18/2018 at 20:17 (2,251 days old) by bendixmark (Winchester Mass)   |   | |
I had no problem getting a valve for my kds-17 which is the ultimate dishwasher.Your serviceman lied to you that certainly can be fixed. |
Post# 983346 , Reply# 3   2/19/2018 at 05:44 (2,251 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 984994 , Reply# 4   3/2/2018 at 18:03 (2,239 days old) by xmastoo (Washington)   |   | |
Thank you everyone for your advice. My partner purchased the replacement valve and installed it, and the squealing has stopped! Hoping that nothing that else will go wrong, and that the machine will continue to perform for many more years. |
Post# 992373 , Reply# 6   4/28/2018 at 13:01 (2,183 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Its not likely that the new valve is the problem, the water level in the DW when it is done filling in the main wash should almost cover the top of the SS filter.
If not check out your plumbing to the inlet valve, make sure there are no kinks in the supply plumbing, and that the water supply is turned on completely. If WL is ok check to see if lower arm is turning easily [ also make sure the arm is installed with the holes pointing up ] believe it or not I have seen the lower wash arm installed upside-down. |
