Thread Number: 74566
/ Tag: Refrigerators
Frigidaire Imperial cold control |
Post# 983604 , Reply# 1   2/20/2018 at 16:10 (2,250 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 983610 , Reply# 2   2/20/2018 at 16:49 (2,250 days old) by Schlitzerland (Michigan)   |   | |
Yes, that was the hint I needed. Thank you |
Post# 983656 , Reply# 3   2/20/2018 at 23:31 (2,250 days old) by Schlitzerland (Michigan)   |   | |
Would any of you be able to share the OEM part# for the cold control/thermostat? I haven't had and results trying to turn it up on my own yet. Thank you |
Post# 983696 , Reply# 4   2/21/2018 at 10:23 (2,249 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 983739 , Reply# 5   2/21/2018 at 17:21 (2,249 days old) by Schlitzerland (Michigan)   |   | |
The freezer is easily reaching -10f. I took apart the cold control and cleaned the contacts, not an easy part to reassemble. I'm running the unit to test, but so far I still believe a new thermostat is needed. |
Post# 983742 , Reply# 6   2/21/2018 at 17:30 (2,249 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
