Thread Number: 74595
2018 Speed Queen...my thoughts have changed.. |
Post# 983830 , Reply# 1   2/22/2018 at 10:37 (2,248 days old) by Yogitunes (New Jersey)   |   | |
interesting theory....and there could be others as well...only time will tell...
as were not why exactly they did a change over of the TLer for 2018....as if they wanted to get out of the Residential lineup, they could have stopped at the 2017 model....then again, maybe the 2018 model will only show up in hotels/businesses/commercial coin op type of service... possibility of too many regulations from the DOE, not worth the hassle of dealing with a residential setup..... machines put into Commercial use, such as a laundromat don't seem to be governed with strict regulations like a home machine.... from a business standpoint, it has always been better to deal with Commercial clients, rather than residential customers...if you were running a business, and had to dal with both, I KNOW which one you would prefer... |
Post# 983871 , Reply# 2   2/22/2018 at 16:53 (2,248 days old) by GusHerb (Chicago/NWI)   |   | |
I see absolutely no difference between this machine and Eugenes. The only difference here was that extra rinse was selected. That's more water than even I'm comfortable using. |
Post# 983872 , Reply# 3   2/22/2018 at 16:56 (2,248 days old) by Infusor (Usa)   |   | |
I too am thinking about buying this machine now, i hated it before. |
Post# 983876 , Reply# 4   2/22/2018 at 17:28 (2,248 days old) by peteski50 (New York)   |   | |
From my viewing and watching a few GM adjtub videos I did observe some turnover! My point is if SQ designed a different agitator for this machine it might work better! Any opinions or input?
Post# 983881 , Reply# 5   2/22/2018 at 17:48 (2,248 days old) by chetlaham (United States)   |   | |
Post# 983901 , Reply# 6   2/22/2018 at 19:55 (2,248 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Wow, I'd be thrilled if my MT came even close to that performance. If that's the new SQ I'm pretty impressed. |
Post# 983917 , Reply# 8   2/22/2018 at 22:34 (2,248 days old) by dylanmitchell (Southern California)   |   | |
It's strikingly similar to the rollout of emissions regs on gas vehicles and later diesel vehicles. The first emissions saddled vehicles were terrible but automakers eventually got it right. Diesel regs came later and they're still figuring that out with SCR and Urea, EGR, and DPF and trying to cheat but getting caught. The point is the 2018 SQ may be a misstep as they're figuring out how to maintain cleaning performance of pre-2018 machines while meeting 2018 regs and I hope they'll get it right eventually. SQ's quality doesn't seem to be in doubt these are well-built machines that will last they just need to get the cleaning thing down which is kind of important for a washing machine. It's nice to see the SQ commitment to quality continue but the best build longest lasting machine isn't worth much if it won't clean well.
The 2017 Speed Queens or 2015 or earlier depending on perspective are the holy grail of pre-2018 DOE regs machines like the 2006 Chevy LBZ Duramax, Ram Cummins 5.9 and earlier mechanical version, and Ford ummm well the 7.3 was great but that 6.0 not so much. |
Post# 983920 , Reply# 9   2/22/2018 at 22:48 (2,248 days old) by iheartmaytag (Wichita, Kansas)   |   | |
Post# 983925 , Reply# 10   2/22/2018 at 23:05 (2,248 days old) by gorenje (Slovenia)   |   | |
What kind of dirt exactly lies on those jeans? Are the "wet" spots some kind of stains or are they just wet? If the stains were severe then wow it did a great job! If not, not so. Fresh mud shouldn't be a chalange. I allways judge a washer based on the ability to spotless wash whites without bleach.
Post# 983985 , Reply# 13   2/23/2018 at 12:38 (2,247 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
Post# 983987 , Reply# 14   2/23/2018 at 12:50 (2,247 days old) by Stricklybojack (South Hams Devon UK)   |   | |
How much wash water turbulence does the change in rotation direction cause, and how effect is that turbulence to cleaning the cloths? That is my question on the new SQ. What if it actually cleans most dirt from most cloths better, but does so in less dramatic a fashion unpleasing to those used to standard TL washer dynamics? That's what I wonder about this design and others like it. If it is, "just an H-E TL washer", at least it will be a reliable long lived one...can we say that? |
Post# 983996 , Reply# 16   2/23/2018 at 15:01 (2,247 days old) by norgeway (mocksville n c )   |   | |
I will still stick to my vintage machines! |
Post# 984010 , Reply# 17   2/23/2018 at 16:47 (2,247 days old) by mrb627 (Buford, GA)   |   | |
Post# 984047 , Reply# 19   2/23/2018 at 22:49 (2,247 days old) by twintubdexter (Palm Springs)   |   | |
Post# 984128 , Reply# 20   2/24/2018 at 09:44 (2,246 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
How many gallons of water did this cycle use? I went to the TR7 page at the Speed Queen website and clicked on "specs", but there are no specs there. |
Post# 984146 , Reply# 21   2/24/2018 at 13:17 (2,246 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 984148 , Reply# 22   2/24/2018 at 13:32 (2,246 days old) by Infusor (Usa)   |   | |
For you folks on here saying this speed queen does nothing, watch this video and come back and tell me speed queens are bad. CLICK HERE TO GO TO Infusor's LINK |
Post# 984151 , Reply# 23   2/24/2018 at 13:56 (2,246 days old) by DADoES (TX, U.S. of A.)   |   | |
Water usage is easy-enough to check. I think anyone asking the question understands that the precise usage will vary per the load size (absorption and all that). Determining what is the per-gallon fill at each of the three levels is sufficient info. Set it to run with the water supply turned off and fill it manually with a gallon jug until agitation starts. Have a helper or two and two or three jugs to keep it going consistently. |
Post# 984160 , Reply# 24   2/24/2018 at 16:13 (2,246 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Or put gallon or 5 gallon markings in a trash barrel and measure what comes out as it drains after filling without any fabrics in it at various water level settings, if it has any. |
Post# 984184 , Reply# 25   2/24/2018 at 22:02 (2,246 days old) by 48bencix (Sacramento CA)   |   | |
It looks like you can select Warm Wash Warm Rinse. That is very nice and something I cannot do with my AWN 432, all rinses are cold. |
Post# 984267 , Reply# 26   2/25/2018 at 09:48 (2,245 days old) by twintubdexter (Palm Springs)   |   | |
Remember Betty Furness and her famous "sand test" for Westinghouse? I'd like to see a "Kleenix Test" with one of these new Speed Queens. Toss in half a box (family-size is OK) and stand back. I'll bet every tissue would remain in one piece...maybe the used ones wouldn't be completely clean...but they wouldn't be torn. Now there's a real accomplishment.
Post# 984272 , Reply# 27   2/25/2018 at 10:23 (2,245 days old) by Infusor (Usa)   |   | |
Try a whirlpool cabrio, i bet half the tissues won't even get wet, the other half will be torn to shreds, but nobody wants to talk about those pieces of junk. |
Post# 984379 , Reply# 28   2/26/2018 at 00:00 (2,245 days old) by tolivac (greenville nc)   |   | |
Turn your washer into a pulper to make paper again!! |
