Thread Number: 74785
Maytag Help in Florida |
Post# 986044   3/10/2018 at 09:25 (2,237 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Hi.
I am visiting my parents in Florida. The Washer is leaking oil. I am in the Sarasota Englewood area. Does anyone know of a repair service that would fix this seal and not tell them the machine is junk ? It is running very smooth and quiet so far. I would say this just started as there was no oil on the floor last winter when they used it. The machines came with the house and they love them. Any help would be appreciated. I don’t recall but are there any members that would want to do this repair for a fee ? Thanks. |
Post# 986067 , Reply# 2   3/10/2018 at 13:42 (2,237 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 986080 , Reply# 3   3/10/2018 at 14:39 (2,237 days old) by Yogitunes (New Jersey)   |   | |
I was thinking along the same lines....
shop some local used appliance shops and see if you can find a donor... but just flip the top over to the new base unit..... just mark and disconnect the wires from the water valve and the motor....and re-attach in the new base.... in under an hour you will be back in action.... |
Post# 986091 , Reply# 4   3/10/2018 at 15:49 (2,237 days old) by super32 (Blackstone Massachusetts)   |   | |
Post# 986092 , Reply# 5   3/10/2018 at 15:54 (2,237 days old) by good-shepherd (New Jersey)   |   | |
That looks like a 12 series or later machine which should have the replaceable low lip seal and does NOT require any major disassembly. Looks like this: Relatively easy fix for an honest repair tech. |
Post# 986102 , Reply# 6   3/10/2018 at 17:33 (2,237 days old) by bendixmark (Winchester Mass)   |   | |
You could also just blast the bottom with degreaser and the machine would probably go another 5 years without a problem.I have done it many times. |
Post# 986111 , Reply# 7   3/10/2018 at 19:05 (2,237 days old) by stevet (West Melbourne, FL)   |   | |
Ed, here's a great project for us to work on! Have the space in the garage all ready and waiting for you! |
Post# 986122 , Reply# 8   3/10/2018 at 20:32 (2,237 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 986155 , Reply# 9   3/11/2018 at 08:59 (2,236 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
As Mark suggests, don't repair, just clean everything up, put on a new main drive belt and sit the washer on a piece of low pile carpet or heavy cardboard [ to catch any oil that drips ] and let the washer run, I do this all the time with old leaky MTs and they have usually run another 5-10 years without doing anything.
Next best thing would be putting in a new transmission, top seal assembly, lucubrate the damper, replace the inlet valve, replace the little rubber thingy in the inlet air-gap [ $500.00 ] and then you have a good shot of the washer lasting 5-10 more years, till the timer gives up or the outer tub rusts out.
