Thread Number: 74876
/ Tag: Small Appliances
Advice on purchase of new Food Processor |
Post# 986802   3/15/2018 at 23:33 (2,205 days old) by scoots (Chattanooga TN)   |   | |
About 5 years ago I purchased a Black and Decker FP2500 food processor. I knew very little about these appliances - Mom thought they were gadgets but I was watching Youtube videos and they seemed like real time savers. While I had no complaints about how the unit worked, I hated the way it was made.
I dimly recall the earlier 70's versions that seemed straight forward in the way they were put together. My B&D consisted of many plastic parts that needed to go together *just so* or the multi-interlocks wouldn't line up and the damn thing would not turn on. A few weeks ago -after very light use- the motor started to smoke and I escorted the whole POS to the scrap metal yard. So my question is, are there any recommendations on a replacement? I'm not adverse to a modern unit per se, but I'm concerned that it will be just as balky to get the safety's to work. Perhaps a vintage GE from the 70s? -Thanks.
Post# 986815 , Reply# 2   3/16/2018 at 03:13 (2,204 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Here's some interesting reading material:
www.seriouseats.com/2017/... The best foodprocessors have an induction motor. Both KitchenAid and Cuisinart have started using cheaper motors in some models, so if you want that, check which models have that. Vintage Cuisinart is a good choice. I had a newer Cuisinart with induction motor that broke down after 8 years or so. I replaced it with a Magimix, which is sturdier built than the Cuisinart I had. |
Post# 986827 , Reply# 3   3/16/2018 at 05:57 (2,204 days old) by vacerator (Macomb, Michigan)   |   | |
but my sister says her newer Kitchen Aid is good. It's also among the most costly. |
Post# 986848 , Reply# 5   3/16/2018 at 09:42 (2,204 days old) by panthera (Rocky Mountains)   |   | |
My ancient Cuisinart works perfectly and the new blade (which took forever to get here) is well made.
Our 1970's Black and Decker was an outstanding unit, it held up in everyday use and we'd still have it except for a flood in 2008.
I've had nothing but trouble with our KA Stand Mixers built in the last 10 years, so can't recommend anything they turn out. Whirlpool really is banking on their good name, just like with Maytag and that gorgeous hunk.
I'd go with a vintage Cuisinart or really older Black and Decker. |
Post# 986866 , Reply# 6   3/16/2018 at 11:33 (2,204 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
If you go Cuisinart, look for the classic style, not the new style.
About two years ago I bought the "new" style with the snap on lid and nice brushed stainless look. What a PITA. the seal on the lid traps food and is difficult to clean. the space between the blade and the bowl when shredding allows large chunks of carrots to pass by without being processed. If you can live with these cons, it isn't a bad machine, but if you have a choice before hand; you may want to go in informed. As for the Kitchenaid, the select a slice blade has been troublesome, and it is one of the more expensive models available. |
Post# 986871 , Reply# 7   3/16/2018 at 12:22 (2,204 days old) by Chachp (North Little Rock, AR)   |   | |
I have burned out at least four Cuisinart Food Processors over the past 30 years. The white one below is one of them, I had a DLCX which is a bigger version of this one. Then I had a big one with the three interchangeable bowls which I can't seem to find a picture of at the moment. I either burned them out or the switch broke or something crazy and it was always after the warranty was over.
I finally broke down and bought a commercial one. This thing is amazing and a beast. I used to grind chicken in the Kitchen Aid Grinder attachment twice when I made chicken burgers but not with this thing. A few pulses and they are ground nice and smooth. I add the other ingredients and pulse it a couple of times and they are done.
The best thing about it is if it breaks I can buy all the separate parts to fix it. Hopefully this is the last one I'll buy. But I love this thing. I got a dicing attachment that is amazing. The thing is great. |
Post# 986874 , Reply# 8   3/16/2018 at 12:37 (2,204 days old) by nmassman44 (Brooksville Florida)   |   | |
I just replaced a Cuisinart Food Processor since there was a recall on the S blade and they never sent out the replacement. I kept using the thing until the bowl broke..again...and they are not cheap to replace so after the 4th bowl replacement I said enough. Now I had my original Cuisinart that I bought back in the early 8os from Service Merchandise that was still running and all the plastics parts were still good until a few years ago when the two part pusher fell apart in my hands. The plastic was Lexan and it lasted for a good 28 years...the newer ones the bowls are not up to par in my opinion.
So I replaced it with a Breville. Love the thing and it was on sale at Bed, Bath and Beyonce for $225 plus I used a coupon and brought it down even more. |
Post# 986981 , Reply# 11   3/17/2018 at 11:25 (2,203 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 987010 , Reply# 12   3/17/2018 at 14:58 (2,203 days old) by joeypete (Concord, NH)   |   | |
Post# 987027 , Reply# 14   3/17/2018 at 16:33 (2,203 days old) by perc-o-prince (Southboro, Mass)   |   | |
I like my (newer) KA a lot. Rich bought it for me about 10 years ago when the Robot Coupe from the 70's crapped out. On, Off and Pulse. That's it. The interlock is pretty simple and it has a lot of torque! Chuck |
Post# 987095 , Reply# 16   3/18/2018 at 05:35 (2,202 days old) by Chachp (North Little Rock, AR)   |   | |
And I know I got a good deal. Mine without the dicing attachment retails for I think around $900 or so. I had been watching auctions for a long time and stumbled across this one at $450. I think he had a restaurant and had shut down or something. Not really sure but the machine hadn't seen a lot of use. No one had bid on it which was a surprise to me and I won the auction at $450.
Then I get an eMail from the guy saying when he was packing the box he found a few more accessories that he threw in the box since he no longer had a need for them. He threw in an extra work bowl with lid and an extra S-Blade. He threw in the Dicing attachment with a couple extra blades and pushers. At retail prices he threw in easily $500 in extras.
The last Cuisinart I bought was over $300 and that one lasted only a few years. The switch went out so my pulse was pulling the plug in and out which was annoying. Cuisinart would do nothing since it was out of warranty. The one before that was probably in the Two Hundreds and that one lasted maybe 5 years.
My point of all this is, if this machine lasts as long as I hope it does and I'm not replacing it again in a few years I will be further ahead. And this thing is a beast. Last week hubby wanted hash browns and OMG that thing shredded a couple of potatoes in seconds and with that large feed tube I could do many potatoes at once. So, I know mine was an exceptional deal. They don't come along often but they do from time to time. So if you think you want something like this save some searches and let eBay do the work for you. I buy NOTHING at retail and between eBay and sites like shopgoodwill.com I get some great stuff and some great prices.
The downside of this machine for me is it's big and it's heavy but I found a corner on the counter that works. I put two of those square furniture mover thingies underneath and it slides right out and back in the corner when I'm done. And I promise you this thing does not bounce around when you're kneading some pizza dough. |
Post# 987096 , Reply# 17   3/18/2018 at 05:45 (2,202 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
I replaced my Cuisinart with a Magimix. I must say that the Magimix is built better and the quality of the bowls is much better.
This is the same one as I have: www.williams-sonoma.com/p... |
Post# 987100 , Reply# 18   3/18/2018 at 06:23 (2,202 days old) by tolivac (greenville nc)   |   | |
Sometime I may get the Magimix-the best of food processors-its the household brand of RC. |
Post# 987117 , Reply# 19   3/18/2018 at 10:55 (2,202 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
and it did have the blade recall. the old blade seemed fine but they did send a replacement promptly, using the online application. It's held up well doing extensive processing of tons of cabbages for sauerkraut and making gallons of tomato paste every summer, plus all of the regular kitchen duties. Very satisfied for it's relatively low price. We have the small model at "camp", it's really too limited to do much except grind herbs and spices!
Post# 987231 , Reply# 20   3/19/2018 at 08:44 (2,201 days old) by vacerator (Macomb, Michigan)   |   | |
made in Japan. Never a problem. I don't know if the blade was recalled or not. It's fine. My friends mom had one with out buttons. By the time I went to get mine, it had the on/off/pulse lever buttons. |
Post# 987284 , Reply# 21   3/19/2018 at 15:35 (2,201 days old) by jkbff (Happy Rock, ND)   |   | |
I've got both the Cuisinart Handy Prep DFP-3 and the KitchenAid KFP1642CA...
I got the KitchenAid because it was too good of a price to pass up on SurLaTable, but I wish I wouldn't have purchased it. It works fine. It is so big and there are so many accessories that the accessory garage takes the same amount of space that the unit takes and that's not counting all three work bowls.... I've started using more attachments (RVSA) on my Commercial KitchenAid Stand Mixer just because those are easier to clean than dealing with the Food Processors. Aside from the amount of space the KitchenAid takes up, I absolutely 100% hate all of the interlocks and safety features on it. I get it, don't run it with the lid off, but when you have to fight longer with the lids to get them cleaned and get them aligned and locked, I more than likely could have hand processed everything in the same amount of time... If Bosch comes out with the MUM5 for North America, that will solve most of my needs. I bought a BlendTec thinking I'd use it... That thing is so damned loud I won't touch it. I am trying to find a decent priced sound enclosure for it. The frequency the motor runs at just rips my ears apart. Anyways, if I were to buy something again, I'd buy a used RobotCoupe with at least a stainless work bowl and a plastic work bowl or I'd get a MagiMix. If either of those are unobtainable, I'd buy an older Cuisinart that I could still get parts for. Maybe even one of the new Cuisinart or KitchenAids with simple controls and not a lot of attachments or accessories.. Simple is better. |
Post# 987353 , Reply# 22   3/20/2018 at 01:38 (2,201 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Tonight I watched a video review of the Kitchenaid food processor attachment that matches the stand mixers. What a piece of junk! If I had a food processor that slow, I'd simply freak out throw it against the wall |
Post# 987357 , Reply# 23   3/20/2018 at 05:15 (2,200 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 987386 , Reply# 25   3/20/2018 at 10:49 (2,200 days old) by petek (Ontari ari ari O )   |   | |
Post# 987389 , Reply# 26   3/20/2018 at 11:15 (2,200 days old) by jkbff (Happy Rock, ND)   |   | |
On that KitchenAid food processor attachment: I figured as much as I abused my little handy prep, having something like that hang off the front of my hub... that is a disaster waiting to happen.
Umm.. Until watching the video all the way through, I had no idea there was a square in the chute to lock and unlock the shaft... WTH.. lol. |
Post# 987409 , Reply# 27   3/20/2018 at 13:21 (2,200 days old) by iej (.... )   |   | |
I’ve a Magimix and it really is a brilliant machine! |
Post# 987436 , Reply# 28   3/20/2018 at 17:25 (2,200 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Yesterday I discovered the Black and Decker food processor with dicing blade. I'm seriously thinking about giving it a try (Darryl, read this!) Its way cheaper than KA and it seems that it works fine. Of course I won't expect the same performance or durability of a high end model, but if it works, it's way better than spending $799 on a KA processor |
Post# 987520 , Reply# 29   3/21/2018 at 09:08 (2,199 days old) by panthera (Rocky Mountains)   |   | |
I rarely use any of our KA machines for 'mixing'. Soda Bread is about it. Everything else is their attachments or done by a handheld GE '47' or a real Sunbeam, Model 10 or 11. Ditto blenders and food processors - the food processor attachment which fits perfectly on our 1950's Oster blender base handles 99.99% of my food processing needs. Anything else is more suited for one of the KA attachments or a specialty machine. Our 1970's Black and Decker and our nearly as ancient Cuisinart are great for major productions. Those are rare, though. And, yes, the new knife blade (which took 3 months+ to get here) is really good quality.
Post# 987524 , Reply# 30   3/21/2018 at 09:36 (2,199 days old) by dermacie (my forever home (Glenshaw, PA))   |   | |
Post# 987539 , Reply# 31   3/21/2018 at 12:45 (2,199 days old) by panthera (Rocky Mountains)   |   | |
That 'real' KA equipment is of enormously higher quality than the trash Whirlpool put out for a while. Although their quality has improved slightly (it couldn't get any worse), there's no possible description for it other than 'marginal'. Our local thrift shops have tons and tons of Cuisinart and KA accessories, some quite high end. The meat grinder for KA from the Hobart days, for instance, is every bit as good as the commercial WOLFF I have. |
Post# 987700 , Reply# 32   3/22/2018 at 16:24 (2,198 days old) by neptunebob (Pittsburgh, PA)   |   | |
Post# 987756 , Reply# 33   3/23/2018 at 01:30 (2,198 days old) by mieleforever (SOUTH AFRICA)   |   | |
Ever considered a Kenwood? They produce rather good quality stand mixers, and have loads of attachments, the mixer attachments like the whisk, k beater, and dough hook is of realy good quality and rather strong. |
Post# 987811 , Reply# 34   3/23/2018 at 18:11 (2,197 days old) by vacerator (Macomb, Michigan)   |   | |
but unlike Kitchen Aid being available the world over now mostly, Kenwood is not here in the USA. |
Post# 987844 , Reply# 35   3/24/2018 at 01:42 (2,197 days old) by petek (Ontari ari ari O )   |   | |
Post# 987853 , Reply# 36   3/24/2018 at 03:24 (2,196 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 993166 , Reply# 37   5/5/2018 at 11:01 (2,154 days old) by scoots (Chattanooga TN)   |   | |
I wanted to thank all of you for your generous answers here. I should probably say that if I ask a question that I really have no idea about, I tend to wait until all postings come to and end since I really have nothing to contribute in a conversational way.
I've been looking into it, and I am thinking of going with a GE FP1 or one of the variants from the 70s-80s. I'm familiar with the machine and just need to do small-capacity grating and dicing - nothing too elaborate. I've started making rounds in our second-hand stores, rather than do an eBay purchase. eBay has gotten really too expensive except for really "must have and will never find elsewhere" items. I will say I was interested in the Kitchen Aid attachments, but shy away because my KA mixer has developed problems at the lower speed settings - the motor just jumps from OFF to MEDIUM. I inherited the unit from my mom, so I haven't looked into the age of the unit, or if the motor control can even be fixed. Again thanks for all of your generous insights. |
Post# 1006551 , Reply# 39   9/9/2018 at 04:01 (2,027 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 1006635 , Reply# 43   9/10/2018 at 06:57 (2,026 days old) by Frigilux (The Minnesota Prairie)   |   | |
I have the classic-style DLC-14 Cuisinart. It does nearly everything pretty well, but it excels at bread dough, which is what I use it for the most. Had a (roughly) 2002 KitchenAid as a second processor because the lid and feed tube were a bit simpler to use for shredding or chopping. It really struggled to process even a single loaf's worth of bread dough (around 3-cups of flour).
Really heavy doughs (2-dozen cinnamon rolls; double loaves of multigrain or 100% whole wheat) are kneaded in the KitchenAid stand mixer. The Cuisinart handles everything else without breaking a sweat. I gave away the KitchenAid food processor when I downsized and moved to an apartment in the summer of 2017.
Post# 1125489 , Reply# 44   8/10/2021 at 13:41 (961 days old) by riyaz08 (Chennai)   |   | |
You have to try the robot coupe food processor,they have been in the industry for almost 50 decades. |
Post# 1125544 , Reply# 45   8/11/2021 at 10:24 (960 days old) by mrb627 (Buford, GA)   |   | |
Post# 1125553 , Reply# 46   8/11/2021 at 13:12 (960 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
