Thread Number: 74914
/ Tag: Classified Ad Finds
GE Sensitemp sensor WB21X175 on ebay. $69.99 |
Post# 987317   3/19/2018 at 19:43 (2,223 days old) by ken (NYS)   |   | |
Not a bad price considering what they're usually priced at.
CLICK HERE TO GO TO ken's LINK on eBay
Post# 987330 , Reply# 1   3/19/2018 at 21:51 (2,223 days old) by spacepig (Floridas Emerald Coast)   |   | |
Post# 987387 , Reply# 2   3/20/2018 at 11:01 (2,222 days old) by bajaespuma (Connecticut)   |   | |
Post# 987392 , Reply# 3   3/20/2018 at 11:32 (2,222 days old) by swestoyz (Cedar Falls, IA)   |   | |
I believe the yellow wire sensor is for the later ranges; white wires were for the earlier set-up. I think the distinguishing factor, besides the wire color, is if the burner is labeled "Automatic" it uses the earlier white wire style, "Sensi-Temp" is the revised yellow wire.
As for when the change happened, it appears to have been around the 1960 time frame when the switch changed from a slider to push button/dial. www.automaticwasher.org/cgi-bin/T... Ben |
Post# 987554 , Reply# 4   3/21/2018 at 14:36 (2,221 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This sensor works on the early 8" sensor element ranges, probably roughly 1957-1961-2 ?, usually these early sensors had white wires but I think at some point that all replacement sensors had yellow wires. To work on these earlier ranges the sensor needs to be 10 ohms, the later sensors were 17.5 ohms and also had a different mounting bracket.
Post# 987585 , Reply# 5   3/21/2018 at 21:00 (2,221 days old) by spacepig (Floridas Emerald Coast)   |   | |
Thanks for the replies. The sensi-temp is called "Automatic" on my stove, and it does have the sliding lever vs. the piano keys. It is located on the left front burner which is 8".
I've attached a picture of what the underneath looks like as well as the wiring of the slider (ignore circle around the thermistor--that was for another post) |
Post# 987612 , Reply# 6   3/21/2018 at 23:49 (2,221 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
