Thread Number: 74935
Need Washing Machine Advice |
Post# 987579 , Reply# 1   3/21/2018 at 19:54 (2,220 days old) by bajaespuma (Connecticut)   |   | |
The good news is that usually water leakage isn't as serious or as costly as oil leakage in a Maytag from what I've learned. It might be as simple as a loose hose connection or as difficult as a leak from the poly pump.
The bad news is that, as was said in a recent post, the real geniuses in this organization can't give you serious helpful advice without knowing your machine. The model number would start this process and if you can't find it, you might try looking on the top of the backsplash behind the control panel on a small aluminum plate. Pictures of the machine, interior and exterior, especially the control panel would also work.
Good luck. |
Post# 987583 , Reply# 3   3/21/2018 at 20:48 (2,220 days old) by panthera (Rocky Mountains)   |   | |
I'm not an expert on late model Maytags, but here's a few general things to check until more experienced people join in (and they will): 1) Where water pools is not always a good sign of where it has originated. I swear it is as good at 'tunneling' as electrons. If you can do so without placing yourselves at risk, try spinning a full load of water out while filming (cell phone video is fine for this). Do you see droplets or spray coming out from anywhere? 2) The hoses, although exceedingly well made do have a limited lifespan. Is it possible that there's a minute crack or tear, a rub mark or perhaps an ever so slightly loose connection? 3) The air pressure tube might have come loose at the tub? 4) Sometimes the seal under the plastic rim at the top of the tub fails just a bit. Especially after a thorough cleaning, it can drip just enough. 5) While the pump is super reliable, connections do sometimes come loose. 6) Water lines? line from the water solenoids to the vacuum break? This is under the top panel and probably only accessible if you take it off.
I'd tape toilet paper all around these various places and run a full cycle with warm water. Where the toilet paper gets wet might just give you a clue. |
Post# 987584 , Reply# 4   3/21/2018 at 20:57 (2,220 days old) by Yogitunes (New Jersey)   |   | |
well your somewhat half way there, as knowing it is happening during the final spin.....
but you are going to have to leave the front off, and watch each and every spin cycle to see where that water is coming from....it may happen the first time, or may take many loads before it shows up.... troubleshooting isn't always easy.....but in order to give a diagnosis and repair advice, your going to have to figure out where its coming from.... keep watching, and keep us posted.... |
Post# 987606 , Reply# 5   3/21/2018 at 23:04 (2,220 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Find a Speed Queen Front Loader now while there are still some left. These are the MOST WELL BUILT washer for home use ever. A good chance that you won't ever need another washer.
If you want to stay with a TL look for an old style SQ. There are still some out there but make sure it has the ELECTRONIC controller or the warranty is shortened by 2 years. They are also available, as are the FL, through commercial laundry outlets. If going used look for a low mileage Whirlpool/Kenmore Direct drive machine made between 1988-2005. Those are the best ever for a TL. They wash and rinse well and when something does go wrong they are easy to fix. WK78 |
Post# 987628 , Reply# 6   3/22/2018 at 04:40 (2,220 days old) by wft2800 (Leatherhead, Surrey)   |   | |
Speed Queen, best-built domestic front-loader ever? Not on the basis of all the complaints one reads. Plus, given how Alliance are behaving now, one wouldn't want to do business with them. |
Post# 987638 , Reply# 7   3/22/2018 at 07:34 (2,220 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Trish, As Martin suggested leave the front panel off and watch the machine, as soon as water appears turn off and unplug the washer and feel around and see what is wet and take a picture and post and we can see what is leaking and I can advise what you are up against,
We still have two AWN432 machines new in the box if you want to take a ride to Maryland and pick one up. We can also sell you a SQ Front Load washer, which is easily the best automatic ever sold for home use anywhere in the world, if you are over 30 it will be the last machine you ever need.
Post# 987656 , Reply# 8   3/22/2018 at 10:10 (2,220 days old) by trish (CT)   |   | |
Thank-you! Great group here, and I truly appreciate all your advice & info! Will run my washer open faced this weekend and report back with the evidence ;-) |
Post# 987668 , Reply# 9   3/22/2018 at 12:12 (2,220 days old) by panthera (Rocky Mountains)   |   | |
Post# 988331 , Reply# 11   3/26/2018 at 13:44 (2,216 days old) by vacerator (Macomb, Michigan)   |   | |
center. It was the fill hose from the mix valve to the tub. Spinning tore it near the clamp on the little plastic spray nozzle thing. I cut the torn 1/4 inch section off, and re attached it. |
Post# 988397 , Reply# 12   3/26/2018 at 22:08 (2,215 days old) by trish (CT)   |   | |
Thanks---we replaced the fill hoses few weeks ago when we put in a new valve, so I think they are not an issue. |
Post# 988466 , Reply# 15   3/27/2018 at 13:20 (2,215 days old) by Yogitunes (New Jersey)   |   | |
what vacerator was referring to was hoses inside the machine that can crack/break, or clamps rust away......
its going to be one of those ghost things, where your going to have to hit the right conditions for the water/puddle to show up.....just keep watching.... it may take a while to show up....been there |
Post# 988540 , Reply# 17   3/27/2018 at 22:07 (2,214 days old) by trish (CT)   |   | |
Thanks Good Shepherd---will give it a go. Doesn't sound too complicated! |
Post# 988926 , Reply# 20   3/31/2018 at 07:13 (2,211 days old) by vacerator (Macomb, Michigan)   |   | |
I was trying to say what Yogi told you. I'm not in the repair field. Sorriest thing we did was let that '95 Maytag dependable care fabric-matic go. Older is better, older is more. |
Post# 988931 , Reply# 21   3/31/2018 at 07:33 (2,211 days old) by Yogitunes (New Jersey)   |   | |
Congrats on locating and fixing your small issue.....
you would be surprised how many people would have thrown a machine out over a tiny leak.....only to discover it was something so simple... can be a bit puzzling at times, as you have discovered, a clamp was missing, especially if you didn't know one belonged there.... you may have this all back together, but not a bad time to consider if there are any other clamps rusted/missing, or hoses needing replaced...maybe the belts...a little preventative goes a long way.... check and clean your dryer vent as well.... |
