Thread Number: 74954
Maytag Transmission |
Post# 987781   3/23/2018 at 11:55 (2,225 days old) by tazz (western massachusetts)   |   | |
I'm just about ready to give my A608 an overhaul, I have most of my parts that I'm going to need all except for one. I'm trying to find the 211484 Lug washer for the transmission. If anyone has a spare kicking around I'd be more than happy to purchase it. Dan |
Post# 987785 , Reply# 1   3/23/2018 at 12:15 (2,225 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 987786 , Reply# 2   3/23/2018 at 12:44 (2,225 days old) by tazz (western massachusetts)   |   | |
Haven't torn it apart yet but I was under the impression that it was a maintenance part if you are tearing into the transmission for a overhaul. If I don't have to replace that even better. |
Post# 987818 , Reply# 3   3/23/2018 at 19:21 (2,224 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I have never seen a bad one, the only things you usually need to replace is the oil, lower oil-seal O ring, cover gasket and we often replaced the entire top transmission cover with the agitator shaft & bearings.
Often water gets into the agitator shaft bearings and ruins them as well as problems with corrosion of the plating on the agitator shaft itself.
