Thread Number: 74962
BD vs DD |
Post# 987838   3/24/2018 at 00:03 (2,217 days old) by Losangeles (Muscle Shoals, AL 35661)   |   | |
Hello AW Guys, I have read many threads and am a little confused. I am assuming BD indicates that the machine is belt driven. And DD is for Direct Drive. I have seen both types of washers in action. There are those in the AW club that prefer one over the other. If someone could explain (to a non- engineering type) why this is so. Is it just a matter of preference or something else. Also I am in the middle of my first restoration of a Kenmore Limited Edition (electronic control). I would like to share the experience with you if there is an interest, but am unsure how and what forum. I see other members sharing there restore with the AW family and I would like to do he same. I have the machine pretty much torn down except for the transmission, which seemed to be in good shape when I ran a few loads of laundry through. The only problem was a leak most likely coming from the tub seal. But while I have it broke down I am replacing the inlet valve, the drive block and nut, the air dome, drive belt, tub ring seal, tub bolts and rubber seals and possibly a new pump. The machine spent most of its life in FL and there was a lot of sand, grit, and pieces of shell coming up into the dispensers and out of the drain. Any and all advice, wisdom, and encouragement would be much appreciated. Thanks, Losangeles
Post# 987842 , Reply# 1   3/24/2018 at 01:19 (2,217 days old) by speedqueen (Metro-Detroit)   |   | |
From what I have read...
BD advantages: *Long stroke agitation, slower, some say gentler. *Less racket, soft "woo-woo" versus DD "clunka-clunka-clunka" *Effective wash performance *Large Capacity *Wide variety of styles, features, agitators over 35+ years from the beginning of AWs to 1986. *Generally reliable
BD Disadvantages: *Lackluster spin, some might say terrible, 505 RPM for large, 525 for standard capacity models *Lousy serviceability, small removable panel at back; cabinet is integral part of suspension. *Metal outer tub -> rust *By now, some parts are scarce
DD Advantages: *Effective wash performance *Best serviceability of any washer *Very reliable *While not excellent, DD spin performance is an average and acceptable 640 RPM.
DD Disadvantages: *Noise *Many complain about rough handling of clothes; "shredmore" and blender like agitation on fast. *Few variations between the early 1980s and 2010, DA agitator and straight vane, only usable one really was the DA
I personally cannot stand DD washers, they have no charm; and that noise, clunka-Clunka-CLUNKA, it is enough to drive me insane! I however recognize their advantages and do recommend them to others who need a washer. We have owned a DD, I have no personal experience with BDs, and as such feel free to correct any mistakes I have made. |
Post# 987848 , Reply# 2   3/24/2018 at 01:59 (2,217 days old) by LordKenmore (The Laundry Room)   |   | |
I like the list posted by Richard.
The only small correction I'd make is the BD plus of "large capacity." That would hinge on the washer--some had small tubs. So if big capacity matters, that needs to be kept in mind when shopping.
Indeed, I saw the small capacity first hand when, thanks to a move, I went from a modern washer (WCI Frigidaire) to a 60s KM with small tub! That said, the KM was a really good washer, and the capacity was big enough to meet my needs. |
Post# 987849 , Reply# 3   3/24/2018 at 02:10 (2,217 days old) by LordKenmore (The Laundry Room)   |   | |
As for my view of BD vs DD, I honestly like BD machines better. But a lot of that is simply the "personality" and sentiment (my mother had a BD machine).
That said...I currently use a DD machine. It works, and gets the job done. I'm not sure how harsh the agitation is. I definitely see wear and tear on some things--but how much of that is washer, and how much is the age or quality of the items that are wearing? I can't say for sure.
I'm not sure I'd get my own DD machine (I rent, and the DD machine here belongs to the rental). But I'd be willing to consider it, simply because of the design's reliability, ease of repair, and parts availability. |
Post# 987851 , Reply# 4   3/24/2018 at 02:42 (2,217 days old) by speedqueen (Metro-Detroit)   |   | |
Post# 987905 , Reply# 6   3/24/2018 at 12:49 (2,216 days old) by speedqueen (Metro-Detroit)   |   | |
Post# 988026 , Reply# 9   3/25/2018 at 09:23 (2,215 days old) by panthera (Rocky Mountains)   |   | |
But first, I LOVE people's stories about how they fixed things. Yes, please! Service Belt Drive: Unless the belt starts slipping, they last for decade after decade after decade. So, yeah, they're no fun to change out, but we're talking about something one does every quarter century, if that. DD: Easy as pie to change out and the commercial 'puck' lasts quite a bit longer. While you're not going to get 25 years + service in daily use out of one, but I've only see two fail in the ten years we've had the two machines using DD. Sound BD: Quiet (especially with the 'quiet pack belt') and pleasant sound DD: Sounds like a Model T warming up on a very cold day. At best. Not crazy about it. Spinning Unbalanced Loads BD: Never once had trouble spinning even one single bath towel out. Never had one go unbalanced yet. DD: Nowhere near as picky about balance as the modern cheap trash, but you do have to provide a reasonably balanced load. Not one Turkish bathtowel by itself. Spin: BD: Not very good. DD: Considerably better, on the portable DD machines, outstanding Wear and Tear: BD: Never seen anything damaged. DD: Depending on the agitator and cycle chosen, there is definitely a reason to fear horrible wear and tear. Poor design. Cleaning: BD: Outstanding. Especially the enzyme soak and double rinse programs. DD: If you use the soak programs and DELICATE agitation every bit as good as the BD. If you use the regular agitation pattern (whether the automatic shift to DELICATE or 'slash and trash' all the way through), your shredded garments will be cleaned well. Make great rags. Wearable clothes over the mid-term, not so much. Fun Factor: BD: These were built back when a washer was an important, aesthetically pleasing purchase. PANK! Turquoise! DD: Except for occasional standouts (early electronic black on black, for instance) they're as ugly and utilitarian as everything else from that era. Almond, yech. Parts availablility: BD: Doable if you have patience but nice to have a 'donor' body on ice. DD: If you don't talk to an idiot Whirlpool Dealer (no support, none, zilch, ice-picks in your eyes level of service) then no problem. So many were built and are still in service, it's not a big deal and you can get the major stuff online. Preference: BD and a good clothes spinner like Thomas Ortega designed and his company builds and markets here in the US.
Post# 988051 , Reply# 10   3/25/2018 at 12:44 (2,215 days old) by chetlaham (United States)   |   | |
Post# 988062 , Reply# 11   3/25/2018 at 14:21 (2,215 days old) by Yogitunes (New Jersey)   |   | |
like them both....yet both have pros and cons...
from our AWO standpoint as some of us like to tinker.....the BD offered some fun to change a variety of agitators, lint filter designs....even a wider belt for a kick up in speeds... the DD offered the full body removal for servicing.... yet the BD was a heavier built unit.... either way, both fun to play with..... |
Post# 988395 , Reply# 12   3/26/2018 at 20:55 (2,214 days old) by norgeway (mocksville n c )   |   | |
A belt drive is a all around great machine in all aspects,a direct drive is a tinny, cheap, flimsy built thrashing machine,I have NEVER seen a DD that didn't have a greasy ring around the top of the agitator, and I have NEVER seen a belt drive that did... |
Post# 990162 , Reply# 13   4/10/2018 at 06:39 (2,199 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
I think I like my DD in the sense that I HAVE a Modern Top Loader, and the shaft, when it broke, was easily replaced...
My laundry room is almost like a Haunted House when the washer is on Fast Agitation, and I think the lightbulbs in the laundry room flash along with that ferocious thrashing... Just wish I could figure out why the washer sometimes doesn't extract the water on Fast Spin--I hear a groaning sound, that if I get right over to the washer as the water is draining (or SHOULD be draining) then I can coax her to spin, or I move the timer around to the rinse in the wash cycle or advance to the mostly-unused second rinse and I get the water out of the laundry that way... -- Dave |
Post# 990212 , Reply# 14   4/10/2018 at 14:05 (2,199 days old) by Washerlover (The Big Island, Hawai’i)   |   | |
Panthera, great dissertation of BD vs DD. Fast spin speeds aren’t all they are cracked up to be unless you like to iron everything. Belt-drive just seems so much more civilized, but I grew up with that so the young kids on this site don’t get it. Really enjoy everyone’s “spin” (couldn’t resist) on BD vs DD!
Post# 990214 , Reply# 15   4/10/2018 at 14:13 (2,199 days old) by LordKenmore (The Laundry Room)   |   | |
