Thread Number: 75075
Maytag A608 rebuild |
Post# 988944 , Reply# 1   3/31/2018 at 11:30 (2,189 days old) by Tazz (western massachusetts)   |   | |
Second attempt....... YEAAAAA
Post# 988949 , Reply# 2   3/31/2018 at 12:25 (2,189 days old) by scoots (Chattanooga TN)   |   | |
Post# 988951 , Reply# 3   3/31/2018 at 12:39 (2,189 days old) by Tazz (western massachusetts)   |   | |
Oh yeah, came off in one piece, it was just really stuck, a bunch of corrosion on the shaft. It looks like it will clean up nicely though. I'll get some more pics later...... Watching the Bruins now. |
Post# 988957 , Reply# 5   3/31/2018 at 13:32 (2,189 days old) by hippiedoll ( arizona )   |   | |
Post# 988969 , Reply# 6   3/31/2018 at 15:01 (2,189 days old) by Tazz (western massachusetts)   |   | |
Not so pretty now..... Had to cut the drum nut off, not a big deal as I have everything I need for tools to do a job like this. Tank has a bit of corrosion especially where the top seal is but I'll get it cleaned up at least enough for another 20 years. |
Post# 988983 , Reply# 7   3/31/2018 at 16:22 (2,189 days old) by good-shepherd (New Jersey)   |   | |
Whoa.. that has to be one of the most corroded agitator shafts I've seen. No wonder a homemade crane was needed to remove the agitator |
Post# 988989 , Reply# 8   3/31/2018 at 16:38 (2,189 days old) by Tazz (western massachusetts)   |   | |
Got the tub nut and associated hardware off, the set screw wasn't seized how about that. I did have cut and break the tub nut off though, wasn't so bad although everything seems to have a lot of corrosion...... No wonder the machine was growling at me....... |
Post# 988991 , Reply# 9   3/31/2018 at 16:54 (2,189 days old) by Tazz (western massachusetts)   |   | |
A good look at the shaft..... Ugly. The bearing is also seized to the housing. I gotta get this apart and cleaned up... We'll see if it's salvageable.
Post# 989000 , Reply# 10   3/31/2018 at 17:47 (2,189 days old) by Tazz (western massachusetts)   |   | |
Got the bearing off, same way as everything else... Had to cut it off. Looks like I'll be looking for for a transmission or at least a top half with the way this shaft looks, cleaned it a bit and it only looks worse. |
Post# 989006 , Reply# 11   3/31/2018 at 19:28 (2,189 days old) by Tazz (western massachusetts)   |   | |
So... Anyone know where I can find a good used transmission? I told you all, Murphy lives at my house, you all have nothing to worry about.
Post# 989013 , Reply# 12   3/31/2018 at 20:05 (2,189 days old) by Ultramatic (New York City)   |   | |
Post# 989014 , Reply# 13   3/31/2018 at 20:06 (2,189 days old) by Tazz (western massachusetts)   |   | |
That's what I figured, just waiting for him to notice this thread. |
Post# 989015 , Reply# 14   3/31/2018 at 20:08 (2,189 days old) by Tazz (western massachusetts)   |   | |
I gotta look on the bright side, it does look like delicious chocolate now doesn't it, just as thick too |
Post# 989016 , Reply# 15   3/31/2018 at 20:11 (2,189 days old) by Tazz (western massachusetts)   |   | |
And here I thought that this was going to be a easy job, quick and simple, tear it apart, clean and inspect then back together..... HAHAHA...... HAHA...... HA |
Post# 989017 , Reply# 16   3/31/2018 at 20:36 (2,189 days old) by stricklybojack (South Hams Devon UK)   |   | |
Post# 989024 , Reply# 18   3/31/2018 at 21:58 (2,189 days old) by robbinsandmyers (Conn)   |   | |
Post# 989080 , Reply# 20   4/1/2018 at 11:44 (2,188 days old) by tazz (western massachusetts)   |   | |
I'm not real worried about the mess as I'm doing a complete rebuild but you are correct. I really wasn't expecting that much fluid in there either, talk about being over filled. |
Post# 989112 , Reply# 21   4/1/2018 at 19:17 (2,188 days old) by robbinsandmyers (Conn)   |   | |
Post# 989126 , Reply# 22   4/1/2018 at 21:14 (2,188 days old) by good-shepherd (New Jersey)   |   | |
Water in the trans oil would account for the overfilled condition. |
Post# 991374 , Reply# 23   4/19/2018 at 07:10 (2,170 days old) by tazz (western massachusetts)   |   | |
Still trying to find a transmission. After I cleaned up everything both sets of bearings for both shafts are pretty well used up. I'll post up some pics soon.... |
Post# 991392 , Reply# 24   4/19/2018 at 10:36 (2,170 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
