Thread Number: 75092
/ Tag: Refrigerators
GE LH-110 -- Help! A wire broke off of the compressor |
Post# 989150 , Reply# 1   4/2/2018 at 01:16 (2,215 days old) by rp2813 (Sannazay)   |   | |
I can't tell from the picture where that wire belongs, but anyone with basic refrigeration knowledge would be able to figure it out. And yes, that whole area looks clean and sparkly!
Giving this a bump so others here will see this.
We had a refrigeration expert here for many years, but now you have to pull up the monitor top web site to find him. His name is Travis. Tell him Ralph sent you, and he should be able to refer you to someone who is familiar with refrigerators of your vintage. The monitor top site has a forum for "other vintage refrigerators" under the "miscellaneous" heading, so you should be able to get some advice there. It's free to join. Here's the link: CLICK HERE TO GO TO rp2813's LINK |
Post# 989151 , Reply# 2   4/2/2018 at 01:26 (2,214 days old) by speedqueen (Metro-Detroit)   |   | |
Are those two ends of wire what broke? If so, find someone you know that can solder and just have them solder them together and heat shrink it, then start saving up for a complete rewire. I cannot imagine it would be cheap. Wire itself is cheap, but the process is laborious. You could replace the wires yourself, it shouldn't be too bad of a job, just time consuming(henceforth expensive at appliance technician rates of $45-90/Hr). |
Post# 989152 , Reply# 3   4/2/2018 at 01:41 (2,214 days old) by rp2813 (Sannazay)   |   | |
Post# 989155 , Reply# 4   4/2/2018 at 02:25 (2,214 days old) by neptunebob (Pittsburgh, PA)   |   | |
Post# 990325 , Reply# 5   4/11/2018 at 15:25 (2,205 days old) by RP2813 (Sannazay)   |   | |
Click on the link to see a thread that will provide some helpful information about which wires do what on your compressor. If you can see the terminals where the wire connections are, you should be able to figure out where the blue one belongs.
A rewiring job by a pro could turn out to be rather costly and may not be necessary. CLICK HERE TO GO TO RP2813's LINK |
Post# 990690 , Reply# 6   4/14/2018 at 09:55 (2,202 days old) by appliguy (Oakton Va.)   |   | |
According to my dealer brochure pages the LK11 is a 1953 model that is a two door fridge with vertical door mechanical latches which were a one year feature, prior to`53 the door latches were horizontal and were again in '54'& '55 before they started using magnetic door latches in '56.........PAT COFFEY
Post# 990705 , Reply# 7   4/14/2018 at 14:00 (2,202 days old) by RP2813 (Sannazay)   |   | |
Post# 990968 , Reply# 8   4/16/2018 at 11:58 (2,200 days old) by appliguy (Oakton Va.)   |   | |
